Why are Nacra dagger boards tapered forward at the top?
Technical Help
3
Posts
3
Users
0
Reactions
1,743
Views
Hi,
Does anyone know why the Nacra (5.2 and 5.8 generation etc) dagger boards slope in at the top? e.g.:
Sometime I find when I pull them up from being all the way down they jam a little if not pulled up straight, I might need to put a bit more carpet in a key spot but if they didn't taper at the top then they would only be able to come up straight?
Anthony
Posted : July 8, 2017 1:59 am
Reduced windage. Later boards cut a large handle hole as well. In higher winds you wouldn't be running the boards all the way down and having a foot of board sticking up above each hull hurts performance. The slope also helps your body slide off the top of the board if you fly into it during a pitch pole.
Posted : July 8, 2017 6:17 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
