Where can I get daggerbd slot liner?
I have a nacra that needs some of the fuzzy daggerboard slot liner seen in this photo link:
http://www.flickr.com/photos/64069794@N03/8486659088/in/set-72157632794478867/lightbox/
It is about 1" wide and is kind of like a brush, not a loop carpet. I have used strips of indoor/outdoor carpet before with some success, but I would like the 'real thing'. I know that Murrays sells the carpet similar to what I have been using but I don't want to use that.
Anyone know how to get more of this ORIGINAL liner?
Thanks!
j
J,
Save yourself a huge headache and go to Lowe's HomeDepot and buy a yard of outdoor loop carpet. Cut it into 1" wide strip. Install with contact cement. Give it a day or two to dry.
This is exactly what Nacra provides today, if you were to get a hold of them. Works a lot better than the fuzzies, and a whole lot cheaper.
i've used the carpet solution on 4-5 hulls so far. if i line the whole perimeter of the slot with carpet, it's too thick & tight to even slide the daggerbd up and down. there is no 'give' to it like there is with the brushy liner.
i've resorted to just doing the forward and trailing edges with carpet which works best, except sometimes the trailing edge of the board will catch on the carpet at the back and peel it loose when pushing the board down.
the nice thing about having a liner of some type is that it reduces the scratches that can happen to a daggerbd that doesn't have padding. i used to use a bungee to pull the board forward and give it some tension but i found the trailing edge was taking the abuse, so i changed to the carpet.
Murray's Catamaran
Gordon
Nacra 5.5 SL
Macgregor 22
I just re-did my I-20 before Memorial Day. I used the commercial grade indoor/outdoor carpet from Lowe's. I used the Marine grade 2 part epoxy to glue it down. All went good except,it takes a while for the epoxy to begin to cure, so need to hold it in place for a hour or so before it begins to set. The epoxy according to the packaging can be mixed and used under water. True the slots are tighter, but like the idea of the blades being locked in. One slides easier and the other is kind of firm. I did re wax the boards before using them. I'd rather have a tight blade then risk loosing it in a capsize or causing damaged to the board or slot when striking something.
Has anyone thought about or tried using the two part spray on/roll on/brush on bed liner material? Seems like it might work and I've thought seriously about giving it a try on my Nacra 5.2 projects. You should be able to build it up as necessary in the areas that you want. Then sand or carve as needed to get a nice fit.
I'm also giving consideration to the 3M Paint Defender product. Spray it on the dagger in the areas of concern to add bulk. It will also protect, and can be removed when you want to replace it. I think you can get it at Auto Zone. http://3mauto.com/paint-defender-spray-film.html
Also thinking about spraying it on the underside of the hull just as a test to see how it protects.
Here is a link to something that might work. I was thinking of trying this out but just ended up using female velcro with peel and stick.
http://www.apsltd.com/c-2868-v15ruddertilleranddaggerboard.aspx
π
Nacra 5.5SL
davidsd wrote: Here is a link to something that might work. I was thinking of trying this out but just ended up using female velcro with peel and stick.
π
Actually you can make this stuff yourself... Get some 3M 300LSE and some nylon/polyester felt from any fabric store and marry them together... this is what APS does..
The trick is in the 3M 300LSE....
