What about installing winch and cleat for main sheet..... Hobie 18
it shouldnt be that hard. i would check:
battens aren't over tight
mast track is cleaned and lubed
there are no pinches in the mast track
the bolt rope hasn't swollen up
the halyard is as thin as possible
the cheave inside the halyard block is in good shape. at the top at the mast and if there is one on the bottom as well
i got my main running smooth although that hook at the top is a mother. i drilled and tapped my mast near the foot installed a cleat and am now tieing it off the main halyard every time. its simple, painless, and dont see why hobie never went with it in the first place
81' Hobie 18
Lake Michigan South Shore Line
If raising and lowering is that bad something is binding and a winch would likely allow you to bind badly and wreck your sail, the halyard or the track. They don't always go up entirely smoothly but it sounds like your setup isn't working right. Also if the boat isn't facing direcly into the with the bolt rope is sure to bind a few times while raising. I regularly spray my bolt rope with silicon spray and that seems to help alot.
On easy option would be to rig up a block on the halyard and a cheek block on the mast and make up a 2 or 3:1 purchase system. Of course you would end up with 80 ft of halyard line to stow...
1981 Nacra 5.2
I think that Andrew and Dave are right. You have something going on that shouldn't be happening. If it was supposed to be that hard there wouldn't be thousands of them sailing without tieing off the main halyard. BUT if you like that method by all means stick with it.
Terry
Nacra 5.2
when you run your sail up the track and it catches the hook you have what it was designed to handle
if you run your halyard up, around a block and back down to the foot, you have just doubled the force on the mast. If you have a comp tip.. this could be trouble.
if you don't have a comp tip.. you still have double the force on your mast and COULD be a problem ... thats why they use a ring on top, or a bead on a wire halyard that fits into the fork ontop
edited by: andrewscott, Aug 20, 2010 - 09:30 AM
Still interested in specifically what you are having a problem with. In addition to what is mentioned above I have had headaches with unhooking the main. The problem was my knot. My bowline was too long and the knot was hitting the block at the top of the mast before it could clear the hook (yes I was rotating the mast after pulling the halyard).
Many H18 sailors remove the flapper that came with the older boats - I removed mine and it made hooking the main much easier - Hobie even recommends removing the flapper.
David
'84 Hobie 18 SE
i never used a bowline with my ring (h18 or current cat). Always a stopper knot (fig 8)
of course there are different ring types. and i am knot saying (pun inteded) that a bowline is wrong, just different from what i do, and have seen
I have my knot facing back, but have been told it works best facing forward on an h18 (didnt on mine).
I also have been told i am rotating my mast incorrectly when i lower my sail... but it almost ALWAYS comes down without a hitch (pun intended),
Thanks for the info. My halyard ring is the style that has a "segment" bar from about 12 o'clock to about 4 o'clock across the ring. So now I have the bowline at the 4 oclock and a clove hitch at the 12 oclock positions. Put a couple twists in the halyard before attaching the main and this has been working well. Like you say definately face the knot away from the mast.
HA - when I read (fig 8) in your post I started looking for figure 8! Man I need to get some coffee.
David
'84 Hobie 18 SE
Kevin,
I had a lot of trouble with unlocking my halyard from the lock at the top of the mast. I bought a Murrays halyard ring and that solved the problem, halyard is easy to unlock. I have a comp tip mast on my Hobie 18 and I use a stopper knot setup to be able to get the halyard up as much as possible. Anyways the shackle was a real deal changer as I wanted to take my halyard lock off as well due to frustration getting the halyard unlocked. Try it again with either the hobie shackle or the Murrays shackle with stopper knot setup or have the halyard spliced to the shackle. Also spray the bolt rope with Mclube before you hoist the sail, it makes a huge difference. Good luck. Ryan
edited by: rssailor, Sep 03, 2010 - 01:34 AM
Kevin219 wrote: i tried mclube and different shackles and all kinds of stuff at the top there. Im a cleater now and ive never looked back. simple is always better.
Whatever gets you on the water I guess, but I wish I could be there with you raising your sail just once and I guarantee you would decide the hook is superior afterwords. There are small equipment and technique details that make all the difference but are hard to describe.
To me the hook IS the simple way and is used by almost all beachcats. Putting the halyard under tension by cleating makes it impossible to keep the sail fully raised and get proper downhaul tension due to stretch in 28 feet of halyard. Also you are putting stresses on the pulleys at the top and base of the mast they are not intended to see.
In my opinion this is the ring that works best on the Hobie 18, on this one you put the halyard through the small hole and tie a stopper knot.
The stopper knot should end up on the mast side of the ring when the ring is attached to the sail, that way the pressure of the halyard pulling up tilts the ring slightly towards the hook instead of away from it.
Kevin219 wrote: crew an i just got off the water. hull flying at midnight!!
Hey that's awesome. I haven't done it this year but full-moon sailing makes even my muddy local lake look beautiful. We even used to have the "Dead Elvis Regatta" with the start at moon-rise in August. Good Times.
~~ I was having trouble with my 17 Hobie ring & hook not catchin up there and I wanted to play with my toy, so I got it up tight, tied it off at the base and went out sailin... got out there a few miles~~ the line broke, and it was good line..... That's why they have a hook & ring, no strain on the halyard.........
~~popeyez7~~
~18 Hobie mag~
~17 Hobie w/ super jib~
~2 Kayaks
~ jet-boat 150 hp.
~~ Vietnam Vet. 69-71 ~~
For the geeks among us.....the original patent for catamaran halyard design. Circa 1978. Coast Catamaran Corp.
http://www.freepatentsonline.com/4077347.pdf
David
'84 Hobie 18 SE
I find that the segmented ring with a twist shackle works perfectly, Never had a problem once I figured out how to use it- Rope/knot ties to the smaller segment (smaller area in the circle). The knot type makes little difference with this ring. Raise it with the larger segment on the Right side of the mast going up (knot on left). It'll hook every time with the mast strait back or close to it. To lower, raise with the mast strait back then turn base to Right. The wind is a factor to some degree. It always works (agian, once I figured it out with lots of binocular time!) I love the system.
Hobie 17, H18, P19 Vermont
did you have to worry about navigation lights?
We didn't, but remember this is not a really large or busy lake (especially at night) and with the full moon on a clear night you can see clearly.
Sometimes we've used red and green glow sticks taped to the shrouds, but not every time.
damonAdmin wrote: [quote=Kevin219]
coast guard regs don't require nav lights on non powered vessels under 21'.
BUT it is a bit dangerous to "drive without headlights on at night" esp if your where a power boat may go. some power boaters fly at night relying on their radar...
when i find myself out after sunset....
What i do is wear a very bright led headlamp, upside down on my head, light shining up at my sails for others to see me.
I also recently found some good led red and green battery powered glowsticks (from publix supermarket of all places). Walmart sells a crappy one as well. I hang these off my side stay chain plates below the deck line.
regular glowsticks have a very limited range (you can only see them under 60' but the power ones can be seen for a few 100'.
the most important thing to keep in mind is DON"'T LOOK AT THE LIGHTS. it will kill your night vision.
i read in a book otherwise but your right drew thanks
I forgot to mention, by cg rules you ARE required to have a torch (flashlight)
INTERNATIONAL
Lights and Shapes
RULE 25?CONTINUED
(d)
(i) A sailing vessel of less than 7 meters in length shall, if practicable,
exhibit the lights prescribed in paragraph (a) or (b) of this Rule, but if
she does not, she shall have ready at hand an electric torch or lighted
lantern showing a white light which shall be exhibited in sufficient time
to prevent collision.
Page 84
http://www.navcen.uscg.gov/pdf/navRules/COMDTINST%20M16672.2D_NavRules%28Corrected%29.pdf
PS there could be local laws that require running lights (i think)_
A flashlight attached to the mast and pointed on/up the sail also does a good job of making you more visible at night also. I like the idea of the headlight pointed up too. All my night sailing has been small lakes and full moons, and we haven't seen powerboats.
Hobie 18M in Chicago
