Ways to secure a catamaran on the beach
Good morning,
I am looking for ways to safely pull a catamaran on the beach and then secure it against the Wind. I saw a few flying catamarans in the previous years around the lake and would definitely like to avoid it. Any simple ideas would be appreciated. The catamaran always stays near the water. I made a search on the site, but English is not my mother language. Please redirect me if this was covered in the past.
JT
If you shoreline is sandy, you can use earth augers, approx 24-30"
to screw into shoerline they have an eye on the top that should be
almost flush with ground tie a rope to each corner of frame or 1 at
bow and 2 each side at rear X beam. i remove mine for winter, doug
Hello JT,
When I take my cat to foreign beaches ( France, Texel ), I always
bring 2 used 13" car tyres and a army-style spade (folding) .
With some strong rope, tie a loop around the tyre, about 1.5 meter
in diameter.
Start digging the tyres in as deep as you can, only 1 or 2 inch
of rope should stick out of the sand and make sure you fill the tyres
with sand when you burrie them.
Now you have 2 eyes to secure your cat with line or straps.
Last Texel race we had Bf 9 on the beach and some cats went flying,
ours was save and secured.
Cheap and easy solution.
Regards, André
Edited by catmodding on Apr 15, 2013 - 01:55 AM.
P 18-2
I dig tiedowns into the sand - 2 vertically up the beach, positioned at the front x bar and the back x bar. I've seen them endo on the beach if both front and back aren't secured. Dig them deep enough that only the ropes are sticking out. Tie to the front and rear x bars, in the middle of the beam. That way if the water reaches your boat, it can't float and fall back down on top of the posts when the water recedes (I've scratched up hull before with post to each side of the boat). Also I remove the plugs when beached, so if the boat floods, it sinks and stays put rather than floating around. I might not do that with a newer boat but it works fine for old beaters.
Edited by Sawyeraj on Apr 15, 2013 - 07:43 PM.
AJ Sawyer
