Wave disassembly
(@ctcataman)
Master Chief
How much force is needed to get the hulls off the cross bars? These may never have been apart and seen plenty of salt and sand. Pulling by hand didn't budge them. Figured I would check k in here before using the rubber mallet. Where to tap and lubrication suggestions appreciated. Thanks.
Posted : January 31, 2017 2:22 am
i helped pull apart a bravo
it required a good amount of force... i can't recall if we used a mallet but we had 2 strong guys working on it
Posted : January 31, 2017 6:12 am
Charles Smith
(@BigWhoop)
The boat is held together with the trampoline lacing. Mine just pulls apart when the tramp is removed. The only thing holding up the pull apart is the skeg dragging on the grass.
If you do this by yourself you have to go bit by bit, front, back, front, back, ... you get the idea. If you don't pull the hulls apart straight the crossmember will jam in the tubes in the hull.
But mine hasn't been sitting for several years getting sand and birds nests in the joint when I pull mine apart.
Good luck
Charles :hammer:
Shut up, sheet in, trap out.
Posted : January 31, 2017 9:03 am
and tree and plant pollen, wind blown dust and organic material...
it's always a science experiment when i remove a beam from a hull
Posted : January 31, 2017 9:24 am
(@ctcataman)
Master Chief
Debris royally messes up slip fits in every machine I have worked on. This ought to be interesting.
BTW good avitars. Mine is sort of dull by comparison.
Posted : January 31, 2017 12:01 pm
(@klozhald)
Master Chief
ctcataman wrote: Where to tap and lubrication suggestions appreciated.
Tap as close to the crossbar as possible.
Spray lithium lube in the cracks and gently bang on the crossbar to encourage it in further.
Posted : January 31, 2017 2:19 pm
(@ctcataman)
Master Chief
Got it apart. Tramp rope doesn't want to fit through slot in end cap. No biggie. Will probably drill rivets out to release cap. Thanks.
Posted : February 1, 2017 2:21 am
Charles Smith
(@BigWhoop)
Maybe try the other side? One of my end caps came broken and I repaired it with epoxy filling in the slot. Now the trampoline bolt rope has to slide out the other side.
Lubricant. Everything is easier with lots of lubricant.
Well done on getting the boat apart.
Charles
Posted : February 1, 2017 7:40 am
