Using bow spreader for raising mast? Bad idea?
Technical Help
4
Posts
2
Users
0
Reactions
2,584
Views
Likely a bad idea. The bow spreader is very strong when being pulled at the correct angle with mast up. If you pull on it sideways like you would while raising the mast you will likely break the fittings. The wave has a pretty small light mast, shouldn't be too difficult to raise the old fashioned way.
1981 Nacra 5.2
Posted : July 6, 2011 3:09 am
I sail most of the time alone, I need way to raise mast alone. I thought I will raise mast up to at least half way by hand and then pull it up by line thru block attached to middle of bow spreader and end of forestay, then when mast up all the way I'm holding mast by that line may come ahead and connect forestay to bridle wires.
Posted : July 6, 2011 3:41 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
