Turnbuckle with a ...
Turnbuckle with a roller furling
7 Users
(@peterk123)
My Prindle 18-2 has a roller furling and it is attached to the forestay with a turnbuckle. I just can't get the negative thoughts out of my head regarding the turnbuckle unthreading one day while the furler is spinning. Am I over thinking this or is a turnbuckle just a bad idea here? Thanks Pete
Posted : April 18, 2015 11:32 am
CatsailorMike
(@CatsailorMike)
not good....get a 1/4 inch shackle and be done with the worrying....not even sure the three stooges would use a turnbuckle....just my $.02
Posted : April 19, 2015 4:00 am
André
(@catmodding)
No problem at all, just make sure the counter-nuts ( translation ? )
which keep the threaded ends on the turnbuckle in place are tight
and taped with volcanic tape.
Still not able to sleep ? Replace it with something like this.
Grtz, André
P 18-2
Posted : April 19, 2015 4:54 am
Andres Chianale
(@Andinista)
Or use cable ties
Posted : April 19, 2015 5:44 am
(@peterk123)
Thanks guys.
Posted : April 19, 2015 8:50 am
(@Dogboy)
Or Loctite.
Steve M.
Posted : April 19, 2015 11:13 am
I believe this is stock for the 18-2 and should not be a problem.
http://www.murrays.com/02-2545-42.html
since you would have to cut off the turnbuckle. you would probably need to replace the entire forestay to change to another system (chainplate or thimbled end) - not a big deal but some Loctite and rigging tape would be cheaper
Edited by MN3 on Apr 20, 2015 - 07:43 AM.
Posted : April 20, 2015 1:42 am
(@damonadmin)
Admin
MN3 wrote: I believe this is stock for the 18-2 and should not be a problem.
HaHa there you go then, never would have guessed what he described was the factory setup.
Posted : April 20, 2015 12:59 pm
