ο‡ͺ
ο…•
οˆ‘
Tiger hull inspecti...
Tiger hull inspection
(@maloose199)
Hi all,
I am looking at picking up a Hobie Tiger and went for an inspection the other day. I was going over the hulls looking for soft spots and found when pressing on the top, water was squeezing out of the join. Is this water in the fibre glass or just in the silicon?
the https://i.imgur.com/J7598b3.mp4
Posted : November 18, 2022 6:49 pm
popeyez7
(@popeyez7)
~~ I don't think I'd buy it... Sound's like that boat is like some people.. ''Ride em hard, put em away wet'' :-D... Go look for another ~~
~~popeyez7~~
~18 Hobie mag~
~17 Hobie w/ super jib~
~2 Kayaks
~ jet-boat 150 hp.
~~ Vietnam Vet. 69-71 ~~
Posted : November 19, 2022 12:55 am
(@danielt1263)
Likely in the fiberglass itself. Unless they took it out just that same day, I would expect the silicon to have dried out...
Posted : November 19, 2022 6:04 am
(@maloose199)
Thanks for the responses, it sounds like it this is a pretty big red flag. I’ll try and drill him down on price as a result otherwise ill just keep up the search for another one.
Posted : November 19, 2022 3:07 pm
(@revintage)
Water in the fiberglass can not be pressed out as someone suggests πŸ™„ .
If you suspect water in the fiberglass it can only be detected by weighting the hulls/boat.
Note the Tiger is built with a foredeck that is glued to the hull, so this indicates a small amount of water between hull and deck.
Unless it leaks water into the hull the problem is miniscule.
The worst that can happen is that you have pry off the lid and reglue it. It can be made in a few hours.
NO RED flag, as this is not within the bearing structure of the hull!
This the center deck plate, the foredeck plate is a lot simpler:
Edited by revintage on Nov 21, 2022 - 06:07 AM.
Posted : November 20, 2022 11:36 pm
