spreader arm and brace on mast Hobie 21SE
Technical Help
3
Posts
3
Users
0
Reactions
1,021
Views
One of our Nacra has SS cotter pins, the other split rings. They’re hard to tape, as there is not much room to get tape around where the wire meets the mast.
I use a Loos gauge & tension them once a year, then slack off when we drop the mast, so the wires are never removed, negating the time advantage of split rings. I have snagged split rings, but never a cotter pin, as long as they are bent so as to stay flush. I think the cotter is thicker material.
My bad, but I only look at the top ones once, in the spring.
Posted : June 6, 2020 4:08 pm
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
