Spinnaker Pole
Hi, all wondering if any of you have a spinnaker pole on a H16 if so wondering if someone can pass on the length of it or is there a required length it is suppose to be.Thank s ahead of time to all.I always appreciate everyones input.Thanks
Just give me wind cause i already got water.
I don't think there was a factory spin on a 16. If you have a spin that you think would fit, you can call the sail maker. They should have an idea of how far in front of the mast the tack should be. If not, you can mock up a pole and see how it looks. If its not factory, there is no set size for the sail or pole.
Hobie USA also sells them
HOBIE 16 Trumpet Snuffer Spinnaker System
20999020 H16 Pole, Snuffer, Spinnaker & Hardware
F16032110 H16 Spinnaker (Colors vary)
http://www.hobiecat.com/media/pdf/eSail_2009-10_international.pdf page 15
