soultions to mast t...
soultions to mast trailering.
8 Users
(@rungi)
Is there a device that can hold the mast securely to the real beam but high enough to clear the tie bar for the rudders. I trailer the boat with the rudders on locally and have a lot of trouble with a good mast support.
I have used life jackets and they work but not well. They are difficult to balance. Anyone know a good solution to this problem?
I would like to be able to rig and secure the boat on the trailer faster and am trying to fine tune the process.
The back part of the mast on the trailer is really difficult to secure quickly.
Posted : September 28, 2021 1:27 pm
(@p-m)
There are dozens of ways to do this. To each his own. A simple strong and effective way is to purchase a 4" schedule 40 PVC coupling and cut out one side to match the rear beam profile and the other to match the mast profile. Secure it with a 1" NRS strap and it will never go anywhere. Fast, simple, effective.
Posted : September 28, 2021 1:51 pm
(@rungi)
Do you have any pictures of a pvc device?
I can't picture what your describing.
Posted : September 28, 2021 3:00 pm
Peter knapp
(@pknapp66)
(@rungi)
I don't like the looks of that. Does it ever move and is it easy to tie the mast down quickly and securely?
Was it easy to cut?
Posted : September 28, 2021 4:49 pm
(@waiex191)
I bought a trailer hitch, and a 2" to 1.25" adapter to make one.
Hitch: https://www.harborfreight.com/3500-lb-step-bumper-receiver-69673.html
Adapter: https://www.harborfreight.com/2-inch-to-1-1-4-quarter-inch-hitch-adapter-65024.html
I welded my mast support onto the adapter. You can see it to the right of the red blower.
I used a rubber bow stop on top of the support:
https://www.amazon.com/gp/product/B002X672YQ/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
I drilled a couple of extra holes in the hitch adapter so I can mount it sideways, which lays down the mast support out of the way.
Posted : September 28, 2021 6:20 pm
Peter knapp
(@pknapp66)
rungi wrote: Thanks
Was it easy to cut?
This is not mine, just an image from the photo albums. Pvc is easy to cut. I know several people who use this
and they work great. Easy to tie around the rear beam. I would buy a cheap contour gauge and try and get a better fit than the one in the picture.
H18m
p16
Venture15
Posted : September 29, 2021 2:24 am
(@geepaks)
Check out Murrays: Rear Mast Support with “V” Stainless Steel
Posted : September 29, 2021 2:53 am
(@texastuma)
rungi wrote: Is there a device that can hold the mast securely to the real beam but high enough to clear the tie bar for the rudders. I trailer the boat with the rudders on locally and have a lot of trouble with a good mast support.
I second the PVC. I am using a section of 15" (it's pretty big, but it was free) and works great. On the bottom, I cut it out to fit on the aft crossbeam and on the top I cut it to match the mast. Local travel (< 1 hour drive) I don't bother with carpet or anything, just bare mast on plastic, but anything further, I place carpet to protect the mast. I have a short ratchet strap that I go around the mast and down to the trailer. It takes about 30 seconds to secure the cradle and mast.
I have used the manufactured special beam to mast clamp and after several years, the tensioning bolt cracks and does take longer to secure than the PVC.
Posted : September 29, 2021 3:58 am
(@charlescarlis)
I've got the Murray's one: https://www.murrays.com/product/13-3002/ and it works really well, but had it not come with the trailer, I wouldn't have bought it. One complaint I have is that it "wobbles" side to side, so I had to add straps to keep it from swaying around. One good thing is that I pull a hitch pin and it rotates down horizontally pretty easily. Had I not got that one, I would've done PVC; the 6" is pretty dang easy to shape with a band saw, if it's a big enough saw.
Posted : September 29, 2021 4:14 am
(@waiex191)
charlescarlis wrote: One complaint I have is that it "wobbles" side to side, so I had to add straps to keep it from swaying around.
Mine wobbles too, but does that matter? I had thought about strapping it for anti-wobble but decided that was just one more thing to do with little benefit.
The Murrays one looks nice, but seems pricey. Mine cost about $50 and is a custom height. Actually I need to adjust the height one more time.
Posted : September 29, 2021 4:20 am
(@charlescarlis)
On mine, the wobble is way too annoying and I think too much - I think it matters due to the weight I have on it, etc. and a line on each side from just under the V down to the trailer holds it really stable. Yeah - it's too much money I think, but it is nice polished stainless. I regularly trailer 45 minutes to an hour at freeway speeds, so I really watch my trailer set-ups (mostly). I mean, it's not like I've drug a ladder at 55 for a mile or so before... 🙂 so, "mostly".
Posted : September 29, 2021 4:30 am
(@p-m)
pknapp66 wrote: [quote=rungi]Thanks
Was it easy to cut?
Through the years I've had everything already mentioned... even layered up a custom contoured carbon support for the N20 that someone stole in P'cola. My PVC support is contoured exactly and almost snaps into place on the beam, zero play, even angled to match the front mast support. One 3' strap reefed inside the coupling and around beam/mast locks everything in place and takes just seconds to rig/de-rig. Keep it simple. Go sailing . . .
Posted : September 29, 2021 4:40 am
(@klozhald)
Master Chief
Put on a hinged rear mast support which takes the weight of the mast from the rear crossbar (and also the hulls) forever. Here are some pictures.
https://www.thebeachcats.com/pictures?g2_itemId=123878&g2_GALLERYSID=13b2f285c737a6c3de6990fef795c6f7
Posted : September 29, 2021 8:08 am
(@rungi)
where do you get those?
do they need to be welded on?
Posted : September 29, 2021 12:05 pm
(@rungi)
your mast also appears to be level
do you have a low front mast support?
Posted : September 29, 2021 3:13 pm
(@waiex191)
rungi wrote: your mast also appears to be level
I'm not sure who you are asking. If you use the quote button that makes it easier to tell.
Posted : September 29, 2021 3:36 pm
