SolCat halyards
Batten Ties - 3/32” (2mm) x 22” (55.9cm) - White (10)
Downhaul - 3/16” (5mm) x 5’ (152.4cm) - White
Jib Halyard - 1/4” (6.4mm) x 22' (670.6cm) - White
Jib Sheet - 5/16” (8mm) x 34’ (1036.3cm) – White
Main Halyard - 1/4” (6.4mm) x 29' (883.9cm) - White
Mainsheet - 3/8” (9mm) x 40' (1219.2cm) - White
Outhaul - 3/16” (5mm) x 8’ (243.8cm) - White
Tramp Lace Center - 3/16” (5mm) x 19’ (579.1cm) - White
Tramp Lace Rear - 3/16” (5mm) x 10' (304.8cm) - White (2)
Trapeze Adjustment - 1/4” (6.4mm) x 3' 6" (106.7cm) - White (4)
Dustin
Magna, UT
Prindle 18
Quarath wrote: https://www.saltydogmarine.com/product_info.php?products_id=3977&osCsid=c903f17d095639722cec88d476b8d578
Downhaul - 3/16” (5mm) x 5’ (152.4cm) - WhiteJib Halyard - 1/4” (6.4mm) x 22' (670.6cm) - White
Main Halyard - 1/4” (6.4mm) x 29' (883.9cm) - White you better double the main halyard it has to go up
Mainsheet - 3/8” (9mm) x 40' (1219.2cm) - White and down the mast .Outhaul - 3/16” (5mm) x 8’ (243.8cm) - White marc
