Solcat 18 Jib Sheet line ?
yogie wrote: What line goes through the center line beam (pipe), and is hooking into a block and tackle system in side the pipe? Is it he jib sheet line?
Fixing up two old solcats, don't have much catamaran knowledge (got boats at a good price, needed a project)
"center line beam (pipe)" - the only part that resembles the pipe that I can think of is center bar connecting front with rear cross bars. 😕
Can you be more descriptive or include pictures?
Yogie, Are you you referring to one of the two cross members that joins the hulls, or are you describing the connecting bar that runs under the tramp? If its the forward cross member that supports the mast, it could be a trapeze line system or possibly your jib sheet setup. My Solcat has a track and block setup mounted to the top of the forward cross bar, but I don't know if all Solcats are the same. As previously suggested, post a picture and you'll get an informed response more quickly.
Here's how to create your own photo albums and post pictures in the forum.
http://www.thebeachcats.com/faq/Forums/pictures-in-forum-faq
Edited by solsailer18 on Apr 25, 2013 - 09:05 PM.
I had a solcat with i believe the same hole you are referring to. I never used it, but i think a bungee went through the hole to hold the trapeeze line. My other Sol Cat had the bungees running through grommets in the tramp, under the tramp, then up through the other side. Then it had little eye bolts that the trap line clipped to.
