Snapped dagger
Unfortunately I'm too busy doing real work right now. 🙁
You can buy the structural closed cell poly foam (airex or other brand) from many sources (don't have any handy right now). Or make a mold and use the 2 part expanding foam stuff from US composites. http://www.uscomposites.com/index.html
Cheaper alternative is to get some western red cedar or balsa blanks for the main body and glass it with fiberglass, carbon or carbon/kevlar. Its denser than the foam, but with a 30 year old boat weight isn't the most critical problem. In the case where you are glassing the blanks having a CNC router would be a huge advantage over having to sculpt them yourself!
There are some good instructions and videos on how to build the foils here: [url=http://http://www.uk-cherub.org/doku.php/tech/howt o"> http://www.uk-cherub.org/doku.php/tech/howto ][url] http://www.uk-cherub.org/doku.php/tech/howto . Toughest thing would be if you want to vacuum bag them to get more strength out of the fiberglassing. Again probably not essential if you put a couple more layers on. I have a guy here who does sailboards that I might try and sucker (convince) into making a set of foils for me.
1981 Nacra 5.2
Here is the supply place i was thinking of to get the foam and other supplies: http://www.noahsboatbuilding.com/noahmain/index.asp?url=IND Of course it's in Toronto.
D.
1981 Nacra 5.2
yurdle wrote: $778 ?!?! I'm sitting on a stack of these. I'd say early retirement time...except:
They break.
I know of no upside to putting one down all the way on a reach, but I'm no expert.
I've gotta reneg on this.. My 5.5 clearly steers better, with much less chance of the rudders breaking free of the water (cavitation?) if I have the dagger 80% or more down. I solo it all the time, which means I'm trying to depower a bunch, but its still a much better sail with the daggers down.
Rob
Nacra 5.2
OKC, OK
