Slack in shroud lines?
During my last sail, I noticed that when we were moving along pretty well that there was some slack in the leeward shroud line. Is that normal? How much preload should be on those things. We were far from flying a hull, just clipping along nicely.
It looked like I could probably have dropped one notch on the adjuster on that side. I could tighten both sides up one notch before I raise the mast next time, is that a good idea?
Kevin
I found the archived article about rigging your boat....take a look.
/wp-content/uploads/images/87863.jpg
1. Pin one shroud where you want it for sailing, pin the other at the top.
2. Raise your mast and pin your forestay where you want it for sailing.
3. Have crew on the trap wire of the shroud pinned at the top, unpin and repin in the proper hole. My crew has to bounce for me to get the pin in the hole I want.
Rig should be tight but the mast still rotate. Sailing upwind the leeward shroud will always go slack except in the lightest of wind.
Ron Beliech
Nacra F-18
Brandon, MS
as a general rule of thumb - the stronger the wind, the tighter your rigging should be (including forestay & jib halyard)
exception is the older h18 races who like a very loose rig in heavy air
nacra55 wrote: 1. Pin one shroud where you want it for sailing, pin the other at the top.
Word.
