Hi, one of the three screws attaching the port shroud chain plate to the hull of my Dart 20 no longer has anything to screw into inside the hull. I am planning on installing an inspection port so I can access the inside of the hull and make repairs. What would be a good location of the inspection port, for example, near the chain plate, or half way between the front beam and rear beams, or something else.
Dan
Posted : October 27, 2012 8:44 am
