Shroud Anchor Plate
(@ctcataman)
Master Chief
Where do I get a duplicate of this. Faint lettering reads ILSE, but not sure that is complete. It's from the Marstrom
2 mm thick, 48 mm hole0 spacing, 22.5 mm (.885 ") wide , 150 mm (6 inches) long , 1/4" holes
Photo in process
Edited by ctcataman on Nov 25, 2017 - 01:16 AM.
Posted : November 24, 2017 5:48 pm
(@ctcataman)
Master Chief
Edited by ctcataman on Nov 26, 2017 - 12:43 PM.
Posted : November 26, 2017 3:37 am
(@tamumpower)
Well good news if you cant find one it looks pretty simple to make.
Posted : November 26, 2017 9:29 am
(@ctcataman)
Master Chief
The plate is doubled up and welded for the shroud pin. Fabricating a plate is easy, but I don't have a spot welder.
What places stock stuff like this? Johnson?
Posted : December 14, 2017 12:08 am
Peter knapp
(@pknapp66)
I would try the place in the link that I added. Also that plate looks identical to the ones on my '76
sailcraft so I assume that it is somewhat of a standard piece. Maybe ask over on Tornadocat. Geoff
Dobbs might have some stashed away or someone may have a parts boat.
http://www.tornado-class.org/marstrom-spare-parts-now-supplied-by-cat-sailing/
H18m
p16
Venture15
Posted : December 14, 2017 1:06 am
(@Dogboy)
All the spot weld does is hold the two pieces together and in alignment before the plate is installed. Once you put the top screw in, the smaller plate isn't going anywhere and the spot weld really doesn't do anything. If it really worried you, you could make the new plate out of a single piece of stainless strip that is the same thickness as the doubled up part you're replacing.
With a little spare time and a few basic hand tools, you could make replacement anchor plates very easily.
Steve M.
Posted : December 14, 2017 7:31 am
