Setup tips
I need some setup tips, especially for the forestay. It used to be easy with our hobie 16 but I need four hands to do it on the prindle. Are you guys just completely detension the side stays, attach the fore and then go back and tension the sides?
Also, I need hints for the areas where it is good to use quick release pins (and what types). Thanks Pete
peterk123 wrote: Are you guys just completely detension the side stays, attach the fore and then go back and tension the sides?
Yes, I just do one side, moving the pin all the way to the top of the adjuster on the shroud. Once the fore stay is pinned, repin the shroud.
peterk123 wrote: Also, I need hints for the areas where it is good to use quick release pins (and what types). Thanks Pete
Quick pins on boom to mast connection and tiller extension.
Snap Shackle on upper main blocks.
Ron Beliech
Nacra F-18
Brandon, MS
i have 1 quick pin on my boat - boom goose-neck to the mast and only because i use it every time i rig. i would never again use one somewhere i don't use it every time (this way you can feel and prevent it from seizing when it starts)
i have seen at least a 1/2 dozen guys try to unfreeze a seized quick pin on the beach and most couldn't... and it stopped several from sailing (couldn't get a broken hiking stick off the tiller crossbar)
everywhere else get a pin and ringding (besides my shrouds, they get shackles for my spin blocks) and i make damn sure they are snugged up with a tool before i launch ... they have a habit of working lose) . If it's a critical area with a pin and ring, i use rigging tape to help prevent the ring catching on something and bending
