Securing my Jib Hal...
Securing my Jib Halyard.
2 Users
begin_it_now
(@begin_it_now)
Another quick question. I feel like a have a lack of places to secure some ropes on my H18. My jib halyard I end up tying to the mast, which doesn't seem right. I also end up tying down the corner of the sail to the mast. What am I doing wrong? The H16 has such awesome tie downs on the mast. Can I install that sort of hardware on my H18?
-Sam
Posted : July 9, 2008 7:13 am
(@damonadmin)
Admin
Yes, it doesn't sound like you have the jib halyard rigged correctly.
On the H18 the jib halyard is a combination of a wire over the top pulley and a two-piece line which is either tied or connected with sister-clips.
When you connect the jib to the halyard, the halyard is placed inside the zippered pocket and runs back down towards the furler, not along the mast.
Once the jib is raised you have a lot of extra halyard, this is untied or unclipped from the short piece of halyard and the short piece is run down to a shackle near the furler, back up through the thimble at the end of the halyard wire, and then down to the plastic cleat on the sail.
Don't fully tighten the jib halyard until the main is up and you can sheet in the main blocks, or you can end up with the jib halyard too tight/loose.
Need some pictures for this, hope this helps.
Posted : July 9, 2008 11:45 am
