Running a dyneema line through dolphin striker eyelet
Sailing a Whisper cat, I need to run a dyneema line that gives strength to the spinnaker pole through the eyelets of two dolphin strikers,
These dolphin strikers are wing-shaped (elongated, length-wise), about two inches long. The piece is carbon fiber, but the eyelet is in a plastic part... the hole is way too narrow for the line, and the line needs to go through around 2 inches.
I've tried very wide masking tape, pushing, pulling, screaming... 🙂 what's your best trick?
If the hole is to narrow for the line perhaps a thinner line or a larger hole is in order.What are the diameters of the line and holes?
If it's just a tight fit situation, the suggestion of tapering the line and using a length of bailing wire inserted into the line is how I would do it. Bend a small hook into the end of the wire and push the wire into the line. Some soap as a pulling lubricant might also help. Good luck, GH
