righting line and/or stretch line system
The previous owner installed a stretch righting system on my Prindle 18 (like the Hawaiian system on the Murray's site).
I also have a righting line installed through the grommet, front and center on the tramp.
It seems since I have the Hawaiian, I can get rid of the righting line. Is the righting line redundant, or necessary?
edited by: kgatesman, Mar 14, 2009 - 04:30 PM
Kenny Gatesman
Chicago sailing at Wilmette
Hi ; I keep a 16'dacron righting line on my P-19 stored topside in the tramp pocket at the mast . I thread the line through the grommet hole in the tramp just in front of the mast & secure it around the dolphin striker bar. I use a bowline knot & plastic ties to keep it from loosening. Last year I tied an additional 16'righting line to the first one & stored it in the same tramp pocket so my crew can have their own line to assist in righting the boat. Tie a small loop in the first righting line & a bowline to attach a second righting line . Good luck ! Bill
Billsails
I found that the Hawaiian system is awesome for Hobie 14s and 16s because you can get it over the hull and get more leverage. It isn't as great on something like a Prindle 16, 18-2, 19 or any other boat that has the beams attached to the hulls (not pylons like the Hobies). It works, but you have to be a) heavy, b) have crew or c) some other aid like a righting bag. They are very convenient. The problem with the line in a bag thing is that the boat goes turtle on you while you are trying to get the line out of the bag and you only have one point to hold on to for two people. The Hawaiian system or the shock cord system lets both people balance by holding on to a wider (not longer) piece of rope. At least, that is my experiance
Dan Berger
Nofolk, VA - Hobie Fleet 32
Supercat 15
A Cat USA139
