Resin, cured or uncured is not biodegradable
Check to see if you have a MRF(Murf), Mixed Material Recycling Facilty. There may be a cost associated but itβs the right thing to do. I have heard California has a boat disposal program that is free for tax payers but still not sure what they do with them as fiberglass recyclability is still somewhat uncharted territory. Seems like they could shred them and stuff car seats or insulate something
Depending on where, you may find there isn't a facility that actually recycles it. As I understand it, its a fairly new process.
Either way, I know in Texas they run a program periodically where people can dispose of unwanted boats. I don't know what they actually do with them though.
I only just found out about the resin thing and have a recycled hull to replace. Found out County does not really hold and generally sends to landfill, so decided to use half of hull, loa, instead of plywood section, as the "shear web" to attach foam to. That way less into landfill. I have habit of not wasting resing ( use left overs for garden masks) and an very anal when comes to pollution...should work out, I can stiffen 16 foot long hull-side, which I think I can do.
Anyone need pylons? Will have two.
