pulling boat using ...
pulling boat using winch
13 Users
(@rungi)
Where is the bests place to attach a winch to pull a catamaran?
I was using dolphin striker rod. Is this strong enough? It is used to right the boat all the wind power propels the boat from this rod, but I don't want to bend it at all or change the tension of the v bar. I just replaced it today because it was slightly bent by the pin when lowering the mast too far before removing pin.
The main beam is difficult to pull from because the trampoline get in the way. I need 2 attachment points o pull it straight onto a trailer or up a steep beach.
Posted : October 24, 2021 7:14 am
(@shortyfox)
Trailer it backwards and you can use a bridle on the rear beam.
Posted : October 24, 2021 8:19 am
(@revintage)
Why not attach the winch to your launching trolly?
Posted : October 24, 2021 9:39 am
(@Edchris177)
Captain
Do NOT do that.
Yes, & no. The rod serves two purposes. From an engineering standpoint, (load analysis), it serves mainly to prevent the main beam from breaking. In combination with the V brace, it makes a truss, which is much stronger than the beam itself.
The short section with the ball serves to keep the mast off the beam, & yes, it does transmit SOME of wind forces, but most of the wind force is borne by the shrouds/stay.
Winching up steep beach via the DS is just dumb. Your ad states “Beach Wheels”, use them. Get them
under the hulls, (about the shroud anchor points is neutral balance), then attach winch to the wheels axles, near the wheels.
If you have to move that cat, remove the rudders & the mast 1st. That reduces the weight substantially, & face it, for whatever reason you are moving it, those parts have to come off anyway.
Edited by Edchris177 on Oct 24, 2021 - 05:51 PM.
Posted : October 24, 2021 11:41 am
(@rungi)
I never remove the rudders. That is too much extra work. They pop up and are not a problem. They would also have to be removed together due to the pivmatic system. The mast is let down when I get the boat on the trailer. It is too difficult to move the boat with the mast down and I don't want to make and extra trip to get the mast. I leave all the rigging attached except forestay. When putting the boat on to the trailer do you just recommend pushing it on.(this can be done but if it is steep it is much easier to winch the boat onto the trailer) I had been getting the bow on to the trailer rollers, backing up the car a little to raise off the beach wheels, then removing the cat trax and winching boat onto trailer while mast is still up. Is the the front beam a safe place to attach a rope to pull the boat up?
Posted : October 24, 2021 12:13 pm
(@dartsailors)
rungi wrote: I never remove the rudders. That is too much extra work. They pop up and are not a problem. They would also have to be removed together due to the pivmatic system. The mast is let down when I get the boat on the trailer. It is too difficult to move the boat with the mast down and I don't want to make and extra trip to get the mast. I leave all the rigging attached except forestay. When putting the boat on to the trailer do you just recommend pushing it on.(this can be done but if it is steep it is much easier to winch the boat onto the trailer) I had been getting the bow on to the trailer rollers, backing up the car a little to raise off the beach wheels, then removing the cat trax and winching boat onto trailer while mast is still up. Is the the front beam a safe place to attach a rope to pull the boat up?
As a newer sailor, I’ll respectfully tell you that’s an incredibly bad idea. If a rudder drops while trailering and you damage or snap it, you’ll be trying to replace an expensive part. Take the whole assembly off.
Here’s your end of day sequence:
1. Drop main.
2. Get beach wheels under boat.
3. Roll oat up to trailer.
4. Winch boat on trailer.
5. Tie down boat.
6. Lower mast.
Posted : October 24, 2021 12:48 pm
(@rungi)
those are the steps i use but i never would take the rudders off
that crazy to me. i would take off if taking a long trip. i do tie them up before driving.
they cant hit the ground even if bungee failed.
Posted : October 24, 2021 1:07 pm
(@rungi)
i also drop the jib. the roller furling is not as cool for the trailering people.
Posted : October 24, 2021 1:14 pm
jonathan162
(@jonathan162)
We're suffering some subject drift here, but wrt the rudders, taking them off for trailering is nothing but a waste of time.
I've put countless thousands of highway miles on cats, and the right answer is to secure them so they can't drop on the road, period.
Posted : October 24, 2021 1:33 pm
tominpa
(@tominpa)
I agree with Jonathan. I have trailered my 5.7 nearly coast to coast with the rudders attached, but secured.
To avoid a very expensive repair, never pull your boat by the dolphin rod. It has no strength in the fore/aft direction, and is there to support the front beam and mast in conjunction with the brace. So it is strong vertically, but can be bent in the forward direction too easily. You can secure a line under the mast ball and the top of the DS against the beam and will have minimal risk damage.
Beach wheels are your friend. I spent many years hauling my cat up on a beach without them, and had to re-glass the skeg. They make everything easier, including loading to the trailer.
Posted : October 24, 2021 2:49 pm
(@rungi)
I do not agree that is has no strength in the fore aft direction. otherwise a windy day would be dangerous.
but pulling it from a certain positions could damage it. I am not sure.
It would be interesting experiment to lift the entire boat from various places on the dolphin striker rod after all the nacra 5.7 weighs 360 pounds should be able to easily support that load. if not the rod should be thicker in my opinion and is an easily correctable engineering mistake.
If one hang weights from rods, which is common, how much weight is actually required to bend the rod from the center point. It is an interesting question. and can be proved experimentally and most likely well known by any metal manufacturing company.
Posted : October 24, 2021 6:25 pm
(@rungi)
clearly the mast lever can bend it if the pin is not removed
Posted : October 24, 2021 6:32 pm
jonathan162
(@jonathan162)
rungi wrote: I do not agree that is has no strength in the fore aft direction. otherwise a windy day would be dangerous.
This is an extremely dumb argument. Edchris177 is 100% correct in describing this as a truss. Anyone who's ever taken a first year statics course understands that trusses are defined and designed in two dimensions, and pulling on it in the third dimension (in this case, fore/aft) is an attempt to rely on a material strength that that element is not characterized for. On any day, windy or otherwise, that element is in compression - end of story. Subject it to a bending moment and you're on your own. It's of the diameter and strength that it needs to be, otherwise you'd hear thousands of stories about them collapsing (folding) in normal use. Fatten it up all you want, and all you'll be doing is engaging in a poorly-considered hack of the sort that just leads to something else failing when you yank on it.
You're getting considered and experienced opinions here. If you're just going to blow them off, perhaps it's better not to ask the question, because that's kind of insulting.
Edited by jonathan162 on Oct 25, 2021 - 04:22 AM.
Posted : October 24, 2021 7:42 pm
(@Edchris177)
Captain
No,they do not. The pivmatic has NOTHING to do with tieing both rudders.
That piece of tubing, known as tiller cross tie separates them.
I’m not against trailering with rudders, if properly secured. My advice was given because you appeared to be having issues getting a 400lb load up an incline. In such a case, the lowest hanging fruit is to reduce the mass.
The easiest way to drop a mast is on an incline, not on a trailer. I’ve watched MN3s friend, (older than I), drop his Nacra mast solo on their inclined beach.
This is my last post regarding this particular Cat. Respectfully, I give up. I’ve sent you almost free parts, & spent far too much time referring you repeatedly to the Nacra manual, along with other sources on this site. Some people follow advice, some don’t.
Good luck with your project.
Edited by Edchris177 on Oct 25, 2021 - 03:27 AM.
Posted : October 24, 2021 9:22 pm
(@revintage)
[quote=Edchris177]
Edchris, I salute you to your decision.
Posted : October 24, 2021 11:32 pm
Andres Chianale
(@Andinista)
Make sure to secure not just the rudders up but also the crossbar centered. It is not uncommon to touch branches, not so likely on the road at speed but before, or when you get home. If you didn’t secure it tight it will be easily pushed completely out to one side and break. And you may even hit others with the crossbar or the rudders. Yes, if you secure things properly there should be no risk. The risk is that one day you may forget.
About rod strength, as said, it stands high loads on its own axis and way less on its perpendicular axis. It’s not meant to be forced horizontally, especially from the lower end. Try hard enough and you will be able to bend it with your hands. You may tie a short loop of rope passing in front of the beam and behind the rod above and below the beam. That would keep the forces close to the beam where the rod strength is not compromised. Where do you attach the righting line? I personally don’t like to attach it to the rod, unless it’s secured close the beam, for the same reasons explained. Next time you take your trampoline out, add a grommet just behind the center of the front beam. The other thing you can do is tying two loops around the beam at each end, just inside the hulls, adding an eye strap underneath the beam to limit side movement. Then add a bridle from which you can attach the winch. You may also attach a tow line there.
Posted : October 25, 2021 12:36 am
you are correct - it has "some" (fore/aft) strength - but your conclusion is wrong
it is designed to manage loads from above
it is meant to stop your mast from ripping through you beam when it has lots of force on it ( sheeted and has wind on it)
it is NOT meant as a method to pull or push your boat horizontally - and if you do, you are adding a lot of force in a critical part that was not meant to have force on it - ymmv
Rudders - every pothole you hit will add wear to your rudders / especially your fittings and bolts and through holes
you can bend rudder through-bolts and cause worming out and adding slop to your rudders - it is up to you if the time savings is worth that risk/ damage (and your specific gear)
IF you travel with them on ... in the up position you risk the rudder causing damage by popping out of the locked up position and slamming down - it is up to you if it is worth the risk and the time savings is worth it. different boats have different systems to keep the rudders up. some a reliable some are not - ymmv
If you drive a few miles on smooth roads - probably not a big deal, if you drive far down crappy roads (and care) ... it's probably worth the time to take em off.
If you look at most modern boats / racers, they take off all the parts, and put them in rudder bag, boom bags, sail bags, etc. It is all an effort to protect expensive gear and make it last
Edited by MN3 on Oct 25, 2021 - 12:27 PM.
Posted : October 25, 2021 2:20 am
Andres Chianale
(@Andinista)
That tow line will work when setup like that, with a bridle, it wont if you tie it to the center of the front beam, the cat will not follow the line. Same for anchoring, if you attach the line at the center of the front beam the boat will be constantly "sailing" around the anchor
Posted : October 25, 2021 2:21 am
(@shortyfox)
That's your best option as long as the load isn't extreme. If by yourself, bracing your feet against the axel of the trailer and you're able to move the boat up on the trailer part way I would say the load isn't too great so winch away. Adding a grommet aft of the beam would certainly work well as long as the grommet is large and has a lot of reinforcement around it. It won't be cheap. Securing the rudders so they won't fall down should not be an issue. The reason for removing them is they stick out and are vulnerable to damage from other vehicles and backing up. With all the boats I've had over the years I have sustained way more damage trailering than sailing. I trailer with the rudders on but that is only because I trailer backwards and I figure they are way less vulnerable that way.
Posted : October 25, 2021 2:36 am
(@klozhald)
Master Chief
Wow.
You guys that trailer long distance with your rudders on really like sloppy steering. I never trailer with the rudders on. Not to Mexico, Coeur D' Alene Idaho, or all parts California and Arizona.
I align my rudders with a 2 mm toe in. I bet the slop in your steering, from the tiller handle to the blade, is five times that.
Trailering with the weight of the rudders on creates wear in the rudder pivots, the gudgeon mounts, the steering linkage, and enhances the gap between the castings and the rudder blade.
You'll note that NO catamaran ever came with a factory device that holds up the rudders while you trailer any considerable distance.
Edchris177, MN3, I think we're done here.
Posted : October 25, 2021 9:29 am
jonathan162
(@jonathan162)
klozhald wrote: Wow.
My rudders and tiller mechanisms are tight and with a similar toe-in. There's only wear where there's movement, and for there to be movement there has to be slop to start with. You're drawing a generalization that isn't necessarily valid.
I'm going to add a long-overdue "shout out" to Bill Frye and his Tiller Linkage Connectors (KISME's TLCs). I got a set from him when I put H18 rudders on my Mystere (don't get me started on the garbage that came with the boat), and to this day they're as tight as the day I bought 'em - even with thousands of highway miles added. They were a beautiful piece of work; when Bill retired he sold everything to Murrays, and when they disappeared from Murrays' catalog I was pissed to learn that they hadn't just discontinued them - they'd scrapped the tooling as well. Damn shame.
That's a completely spurious argument. As a rule catamarans don't come from the factory with trailers, so by your logic they aren't meant to be towed anywhere.
Edited by jonathan162 on Oct 25, 2021 - 04:14 PM.
Posted : October 25, 2021 9:50 am
agreed, mystere's system has lots of flaws. that is why i have a dozen spares of each part 🙂
I have seen nacra rudders on a mystere 6.0 do very welll - never saw h18's on a mystere
Posted : October 25, 2021 11:19 am
jonathan162
(@jonathan162)
"Flaws"? You call a rudder that: a) Doesn't lock down; b) Doesn't lock up; and c) Doesn't kick up a "system [with] lots of flaws"?
I call it "inexcusable crap that, when it's not floating up just for fun is looking for something to hit so that it can explode, assuming you don't replace it with a REAL rudder system first".
Of course, I'm speaking only of the original Mystere 17's - I have no idea what they put on the 6.0 .
Posted : October 25, 2021 11:59 am
(@carbonc)
You sir are quite obviously not an engineer and your claim of an engineering mistake is specious at best. The issue here isn’t just the size and strength of the rod, it’s how it connects to the lower v-bar and runs through the front beam. If your winch line slides down to the bottom of the striker rod you’ve got a lovely moment arm multiplying your winching force. If your rod was oversized that force has to go somewhere and it’s just going to get transferred into trying to deform/stretch the front beam holes. The range here is from direct shear load (assume d from winch line to front beam = 0) all the way to a pretty decent bending moment that is going to act on the striker rod right where the bottom thread is cut (weakest point).
Simply put you’re making an issue and saying it’s a poor design when you’re trying to do something never intended by the manufacturer and obviously a bad choice by any observer for a variety of reasons (as evidenced by the other comments here).
Edited by carbonc on Oct 25, 2021 - 11:58 PM.
Posted : October 25, 2021 5:54 pm
i don't have any of these issues with any of my rudders/casting
mine lock down and stay down unless i am in 30knots and hit grass (been there, don't want to again)
mine don't "lock up' but they do stay up (unless a butterfly lands on them)
mine certainly do kick up when they contact anything more than a guppy
BUT they do die a young life (almost always the crap pot metal fails) and so far Mystere has. been good to work with for spares. I ordered a complete upper and lower casting from them a few years ago and one of the uppers had some casting flaws - they sent me a new one without question
Posted : October 26, 2021 2:32 am
(@shortyfox)
I can't imagine there is no way to tie a line around the main beam at each forward corner of the tramp. What kind of boat? A bridle tied at those two points would make this discussion of using the dolphin striker rod moot. All of this should not be complicated. As far as the rudders go, if you want to leave them on, tie them where they can't fall down but take them off for long trips. Sorry for sounding so pragmatic, but too much is being made of this.
Posted : October 26, 2021 2:38 am
jonathan162
(@jonathan162)
Then we're talking about two different things. The original 17's had no "mechanism" of any sort - just small ledges on the castings that rested against each other in either the up or down position, held in place by a subtle combination of gravity and prayer. I'd be interested in seeing a picture of yours. By funny coincidence, this summer I quite accidentally met a chap at the lake who has a 17 with a sail number just a few away from mine, and I've been helping him sort the boat out. Amazingly, he still has the original rudders, and though they've been endlessly patched and hacked over the years, they still (don't) function as original - apparently in four decades nobody who owned the boat knew enough to have had enough of them. I'll try to get him to shoot me a couple of pics and post them here.
Posted : October 26, 2021 4:10 am
still the same, just a notch on the lower and notch on the upper - that eventually rounds off - as i said they don't lock up but until they are worn round and can no longer be filed anymore (they usually break prior to this point), they stay up. - even on anchor, even with boat and wave traffic
Posted : October 26, 2021 5:32 am
jonathan162
(@jonathan162)
(We really need to take this to a new thread...)
Unbelievable to me that after all these years Sansoucy wouldn't have come up with an actual grown-up rudder mechanism.
I sail a lot of reservoirs, which means fluctuating, unpredictable levels. The local (in-city) reservoir where I learned to sail and for many years kept the Mystere mast-up is just one of them (though it's recently been rehabilitated - it's been steadily silting up over the last half century to the point that much of its area was unsailable, but thanks to the big 2013 flood they modified the dam to raise the level a meter or two, and it's like a brand new lake). The first, maybe the second year I had the boat (can't remember for sure, but could probably find documentation) I quite unexpectedly hit bottom at speed and the tops of both rudders blew off. They were nice enough to send me a new pair gratis, but I sailed the boat extremely carefully until I made a holiday trip to LA and had the Hobie rudders installed while I was down there. I can't imagine putting up with those non-mechanisms except in an emergency situation.
The non-kick-up rudders are even more incomprehensible when you look at the pivoting boards.
Posted : October 26, 2021 5:54 am
(@texastuma)
I have a block and tackle I use to pull the boat up on the trailer, since I mostly singlehand. I have a line with a snapshackle that I wrap around the mast step, down, around the dolphin striker, up, and back around the mast step. I could go just around the mast step, but I want to keep the load as low as possible. When we tow boats (keelboats and catamarans), we always go around the mast or mast step.
Posted : October 26, 2021 10:02 am
Page 1 / 2
