Prindle main downha...
Prindle main downhaul setup
6 Users
(@spags)
Just wondering is anyone can send me pics of their main sail downhaul rigging on their prindle or Hobie. Looking for something simple that involves a pulley system that is quick to setup. Thanks
Posted : September 9, 2018 6:00 pm
(@randii)
Here's a thread I did on Hobie downhaul choices. https://www.thebeachcats.com/index.php?module=forums&func=viewtopic&topic=16899 It may have what you seek?
I need to update that thread to provide a season worth of experience on the double-cascading multiplication system I've run for the last year on the H18, and for new feedback on a simpler (and stock) system run on my Tiger. Quick summary: the double-cascade works well to pull in downhaul, but has more friction than desirable when *releasing* downhaul. It works, just not as smoothly as desired. Oh, and the Tiger mast with tune-able prebend is way more flexible than the H18 mast (I mostly sail the non comp-tip H18 stick). Even so, with enough downhaul advantage and a laminate sail tough enough to take the pull, you can really flatten/depower the H18 sail, similar to what you can do (more easily) on the F18 Tiger.
FWIW, none of this is exactly rocket science, and it is pretty much what other folks told me would happen, I just wanted to try it on my own.
Randii
Edited by randii on Sep 10, 2018 - 11:56 AM.
Posted : September 10, 2018 7:49 am
(@spags)
Thanks... This is helpful.
Posted : September 10, 2018 11:05 am
your (h18) mast is very stiff so it's really working the snot out of your sail matierial
/ you are overworking your sail along the luff and will die an early death by oversheeting your (anything).
there are other methods to reduce heeling that won't hurt your luff as much - so unless your racing ... i would reduce rotation, travel out, sheet out, furl jib, and outhaul before i relied on overworking the luff - ymmv
Posted : September 10, 2018 11:11 am
John Schwartz
(@JohnES)
Spags... is this for a Prindle 15? I have used something similar to this for a 16 and an 18, and probably what I am going with for the 18-2 that I am rebuilding...
Edited by JohnES on Sep 10, 2018 - 07:30 PM.
Posted : September 10, 2018 1:21 pm
(@jalex)
I would put a low purchase on the less modern designs with Dacron sails. It’s just more leverage to pull out a grommet or head plate.
Edited by jalex on Sep 10, 2018 - 10:03 PM.
Posted : September 10, 2018 2:52 pm
(@klozhald)
Master Chief
jalex wrote: I would put a low purchase on the less modern designs with Dacron sails. It’s just more leverage to pull out a grommet or head plate.
The setup JohnES shows looks to be six to one, which is close to the original and should work fine with a standard sail's grommets. A newer flathead sail will be stronger at the grommet by design, ready for a higher working ratio, and possibly a pre-bent mast config.
Posted : September 11, 2018 7:37 am
(@randii)
MN3 wrote: your (h18) mast is very stiff so it's really working the snot out of your sail matierial
I checked in with Chip before really cranking up the downhaul advantage. His comment was something along the lines of -- that's essentially an F18 sail, so it can take the downhaul. I an WAY more delicate with my older Dacron sails.
MN3 wrote: there are other methods to reduce heeling that won't hurt your luff as much - so unless your racing ... i would reduce rotation, travel out, sheet out, furl jib, and outhaul before i relied on overworking the luff - ymmv
I agree with all of these options... learning to balance them all is quite the trick, especially while controlling the squaretop!
Randii
Posted : September 11, 2018 9:19 am
Not trying to be argumentative and I would certainly use a modern sail over a dacron one on any boat:
I totally agree that it is a modern sail - it's the mast that isn't
modern material will hold up and not continue to stretch like dacron does
but when it is fatigued enough ... it just shreds
so getting your sail as flat with a downhaul requires a lot more force to bend the (stiff) mast into that position than it would on a modern stick
so it is harder on your sail than if you were on a bendy mast - imo
Posted : September 11, 2018 10:36 am
(@spags)
Yes johnES... Its for a prindle 15.
Posted : September 11, 2018 1:28 pm
John Schwartz
(@JohnES)
spags wrote: Yes johnES... Its for a prindle 15.
Get these an you'll be set
Posted : September 12, 2018 2:56 am
(@randii)
MN3 wrote: Not trying to be argumentative...
No worries, it is the internet! *chuckle*
MN3 wrote: so it is harder on your sail than if you were on a bendy mast - imo
Besides, we agree!
I love messing around with boats, and I wanted to try different levels of advantage on my downhaul. I learned a lot about it, but sailing on the Tiger has been eye-opening in many ways... downhaul not least of it, and also prebend.
Randii
Posted : September 12, 2018 8:20 am
I had lots of revelations when i stepped up to modern design
the h18 was great but makes you work real hard for any gains
my 5.5 is much much much more responsive
i need to work on my rigging skills to get to the next level myself (rake, prebend, stay and spreader tension)
Posted : September 12, 2018 8:36 am
(@spags)
Thanks for the tips sailors and the pics for the parts. If u can send me a pic of how those parts look on your boat that would be awesome too. Thanks so much.
Posted : September 12, 2018 12:07 pm
