Prindle chainplate question
I went through the trouble to remove both bow decks when 1 bow tang failed
also broke through a (second) bulkhead to replace both side-tangs when 1 chainplate/tang failed
it may not be a bad idea to replace when you have access as preventative maintenance - esp if the cat was used in salt water
Edited by MN3 on Apr 05, 2022 - 08:01 PM.
Posted : April 5, 2022 2:00 pm
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
