Prindle 19 daggerboard question
Technical Help
2
Posts
2
Users
0
Reactions
2,515
Views
My daggerboards have a factory hole whichs lines up with a premolded channel when installed. Is there supposed to be some type of bolt or pin assembly to allow the daggerboards to pivot up in shallow water? I read the online user manual and I didn't find any mention of the daggerboards (centerboards)at all. If there are any P19/18 owners any advice would be helpful. It appears the boards will work fine without the pin....
Dutch
Posted : October 3, 2008 6:30 am
The daggerboards pivot on a standard piece of 3/4" PVC pipe. They snap into some indents at the bottom of the channel you mentioned. The system works pretty nicely. If you need the exact length of the PVC, I think I have a set here somewhere.
Jack
Fort Loramie, Ohio
Jack Hoying
Fort Loramie, Ohio
Posted : October 6, 2008 8:53 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
