Prindle 18 - Little water getting in.....
I am talking about only a cup or so after a day of sailing but my other hull stays bone dry. Since I can't leave well enough alone, I went on a search for the leaky spot. I thing I found it. It appears that water may seep in at the front crossbar. So the question is, should I care? I just placed some silicone at joint between the crossbar and hull, hoping that it will at least deflect that water. I do not want to take it apart right now. I attached a pic of the inside, it looks to be in decent shape. Any thoughts? Is it fairly common to have it seep in here? Thanks Pete
Edited by peterk123 on Jun 22, 2014 - 02:24 PM.
It is common on Prindles, I usually do as you did, put a thin bead of silicone between crossbar and hull, wet finger and smooth it out. The P15 I had, removed crossbars and cleaned out years of crud accumulation, reseated, and sealed entire area of crossbar/hull seat as above.
R
