Prindle 18 Jib bridles / tramp space
I am new to Prindles but I am sure some of you have a neat cure for this. I have an aftermarket tramp which has no gromets in the center. The line between the jib bridles is tight between the bridles, but this leaves little or no space for my crew to sit. I tried removing the line completely for recreational sailing but it wont point for beans. I need a way to secure the bridles in position without taking up the entire front of the Tramp.
Bill Beach
I had a grommet issue with an old trampoline and the shock cord for my trapeze lines. I marked the spots on the tramp and took it to a local boat shop. They were able to add two brass grommets for only a few bucks.
J. Mueller
Prindle 16
J. Mueller
Prindle 16
Muskegon Lake, MI
Put two milk crates under the tramp, then a short 2 x 4 atop. Now take a grommet kit from hdwe store and put grommet just where jib block lies on tramp. Better if you put a 2" sq of webbing under the spot before pounding in grommet. Now tie jib blocks together UNDER the tramp. Have good memories of sailing P-16 in Muskegon. Pete
prindle pete
If you are really looking for tramp space, I would suggest a G-Cat as they have a forward tramp as well. The placement of the jib blocks on the P-18 are for performance not comfort. The G Cat is a great boat, I owned and sailed one in 1980. The front tramp was terrific, at that time they also came with a boom tent for camping, another great feature that I wish some of the manufactures would consider again.
