Prindle 18-2 line set
Does anyone know the specs for a Prindle 18-2 line set?
I'm looking at a neglected boat with (supposedly) sound hulls, spars, and sails. I still need to inspect it, but I want to start pricing out what I need...
Slo Sails and Canvass has a line kit for the 18, but said the 18-2 is different.
At a minimum, I'd need a main sheet, (standard) jib sheet, halyards, righting line, rudder controls, and trapeze lines
Line set? The 18 won't be that much different from the 18-2 so set the boat up with the 18's lines and go from there. Push the boom out all the way against the shrouds and see if you need more or less mainsheet length. Does the 18-2 have a 6 to 1 mainsheet or an 8 to 1? If it doesn't have an 8 to 1, you'd better think about getting one. Diameter is a personal preference; I have always gone smaller because it is smoother and has less tendency to jam.
Anahr822
Go here for data on the 18-2 - standing cable, running rigging, assembly manual and tuning guides.
https://www.thebeachcats.com/pictures?g2_itemId=123714
Over 7000 hits.
Edited by klozhald on Jun 20, 2024 - 12:02 PM.
anahr822 wrote: Does anyone know the specs for a Prindle 18-2 line set?
Murray's Marine will have everything you need..
