Prindle 16 trap lin...
Prindle 16 trap line position
2 Users
westmatt
(@westmatt)
I am working on a boat with ports (my previous P16 did not have ports) and the manual says if you're using a single trap that it should be attached to a block forward of the port, which seems kind of counterintuitive, as that location is farther away from where you'd normally sit, and puts the shroud in between you and the trap wire. What's the reasoning here?
-Matt
Posted : June 25, 2024 1:44 pm
(@shortyfox)
You're right, it makes no sense. I have a single trap wire just about an inch aft of the shroud. I have a bullet block tied real close to the shroud adjuster that the shock cord runs through. The shock cord goes through a grommet in the tramp. Works well, is easy to reach. The stock set up is too forward and is okay for crew, too far away for solo.
Posted : June 26, 2024 3:52 pm
westmatt
(@westmatt)
Sorry, I'm still so used to being rebuffed when I try to post without having logged in that I still don't remember to check before posting.
-Matt
Posted : June 27, 2024 11:58 am
