Prindle 16 tiller extension recommendations
Just bought a 1980 Prindle 16. There was a after market tiller extension but it broke the first time taking it out. From looking at the manual the way the tiller extension connects to the tiller crossbar is also after market. Looking for recommendations on tiller extensions/connections to the tiller crossbar and where to buy.
Criteria:
-Telescopic
-Easy connect to the tiller crossbar
Found 1 option on amazon,but was curious if anyone has any suggestions!
https://www.amazon.com/dp/B004SANKF0/?coliid=I1DCJTRX1M89F&colid=2FDSWZ6B3PZ4E&psc=0&ref_=lv_ov_lig_dp_it
Thanks in advance for ideas!
-Kelsey
Edited by kelseycampo on Aug 15, 2018 - 09:36 PM.
Thanks for the help pete! Would you say that the oem yoke is better then aftermarket? Currently i have the after market (see link below) but it broke. I dont have a preference yet becaise i havent sailed with either so im not sure which is better.
Oem: https://www.murrays.com/product/01-0062/
After market: Ronstan Battlestick Universal Joint (55188) https://www.amazon.com/dp/B0000AXVIC/ref=cm_sw_r_cp_apa_hFpDBbDF0VGMW
I have the Ronstan Battlestick on my 10 yr old A Cat, but wonder when the rubbery swivel portion will break (like windsurfer uni joints). The Murrays stainless steel yoke is only 9.50 and comes with their 65 dollar telescoping aluminum stick. Pete
Edited by pbegle on Aug 16, 2018 - 10:35 AM.
prindle pete
kelseycampo wrote: Just bought a 1980 Prindle 16. There was a after market tiller extension but it broke the first time taking it out. From looking at the manual the way the tiller extension connects to the tiller crossbar is also after market. Looking for recommendations on tiller extensions/connections to the tiller crossbar and where to buy.
Criteria:
-Telescopic
-Easy connect to the tiller crossbarFound 1 option on amazon,but was curious if anyone has any suggestions!
https://www.amazon.com/dp/B004SANKF0/?coliid=I1DCJTRX1M89F&colid=2FDSWZ6B3PZ4E&psc=0&ref_=lv_ov_lig_dp_itThanks in advance for ideas!
-KelseyEdited by kelseycampo on Aug 15, 2018 - 09:36 PM.
arriba hot stick are very widely used around here
but there are many brands, i have used alum, fiberglass and carbon fiber ones
i have used non telescoping and they all have pros and cons
http://www.arribastick.com/
they are nice but have a life span (wear out) - it is possible to service them with some epoxy but ...
as mentioned, most beach catamaran use the yoke style shown above - but anyboat can be modified and every sailor has their own "method" of rigging
Edited by MN3 on Aug 16, 2018 - 07:23 PM.
spags wrote: I just bought the aluminum telescopic tiller for $65. Good price and good quality.
In my experience: Alum sticks don't last long
as soon as you drop it on a corner of your deck lid - it will dent
once it dents ... it's just a matter of time till it fails (breaks in 1/2)
pbegle wrote: I have the Ronstan Battlestick on my 10 yr old A Cat, but wonder when the rubbery swivel portion will break (like windsurfer uni joints). The Murrays stainless steel yoke is only 9.50 and comes with their 65 dollar telescoping aluminum stick. PeteEdited by pbegle on Aug 16, 2018 - 10:35 AM.
Red Gear Racing has these for roughly $20. You can order them direct from Australia but it doesn't really work out price wise when you factor shipping for 1 to the mix. These have lines through them so when the rubber fails you still have a connection to the tiller crossbar:
http://www.rileyfittings.com/pyf_range/tiller_extensions/pyf205
IF you can bear the cost, get a Spinlock EA 2000. It doesn't have a twist telescoping fitting. It uses detent buttons.
The mechanism is all external so it can be rinsed out and lubed. Replacement parts are available. The swivel connection to the crossbar is real nice. The big asymmetric grip relives hand fatigue. When I go to extend the handle it only goes out one button at a time so I don't round up too hard.
I admit they're godawful expensive. I have found it to be worth the price
http://www.apsltd.com/ea-2000s-asymmetric-silver.html
This link is just an example. Shop around for a better price.
Going to have to disagree on the big boat characterization. They're designed for racing dinghies and beach cats. I haven't found the weight to be an issue. I find the beefiness a distinct advantage. It's a personal preference issue. I wouldn't trade mine for anything else.
F
gahamby wrote: Going to have to disagree on the big boat characterization. They're designed for racing dinghies and beach cats. I haven't found the weight to be an issue. I find the beefiness a distinct advantage. It's a personal preference issue. I wouldn't trade mine for anything else.
What about holding the main sheet and the tiller with one hand? Is it possible and easy with that handle? I need to do that all the time from the trap, can’t pull the sheet with the other hand alone.
The "D" handle makes that very easy. I like the "D" handle because I can change hand positions.
All that being said, that Nacra handle does look nice. It has a long reach.
https://www.murrays.com/product/56-30271/
I find it pretty durable. I’ve snapped one once in a capsize righting gone wrong and I repaired it pretty easily and sailed with it for 2+ years that way.
I’ve used 3 versions of the Arriba hotstick and own two. The fiberglass one is durable but stupid heavy. The carbon/Kevlar one I think is equally durable but much lighter. The all carbon one I’m less sure about; I snapped it but in a similar situation as I did the Nacra one.
The most durable extension I have used is a Ben Hall fixed extension. I would use it everywhere but on a spin boat in light air you need something that is quickly adjustable, which is where the Nacra comes in.
There are some other alternatives, the Hobie Wildcat carbon extension is pretty nice. There is also a gentleman that makes quality versions of the Marstrom. I think CST makes some as well.
If someone is in need I have a fiberglass Arriba I could probably part ways with.
