prindle 16 replacement tramp
I just bought a prindle 16 and the tramp is all but gone. so i got one to replace it with. the problem is the old tramp has straps that go thru the outer edge of the hull and is in two pieces. you stretch it from the middle.
the new tramp is one pieces and you stretch it from the hull side.
DID I GET THE WRONG TRAMP?
If you got a replacement tramp for a Prindle 16 you are likely OK. The original tramp is probably just an older configuration. My Nacra was the same way, the original tramp was a 2 piece and the new one is a single piece.
Take a look at the prindle manual on Performance Cats Website. http://www.nacra.us/Prindles/Prindle151618Manual.pdf
If yours is the same as the 1 piece shown in there you should be good to go.
D.
edited by: Wolfman, Oct 09, 2009 - 11:56 PM
1981 Nacra 5.2
thanks wolfman, hullflyer the owners mannual was extactly what i need I had been looking for hours last night for something like that. the design of the tramp must have changed sence the old tramp was put on. the pic in mannual conferm that the new tramp is the right tramp and says how to lace it.
