Prindle 16 Bridle wire replacing
I have a 1972 Prindle 16 and am quickly finding out that the original wires do not last long. I have to replace one of the bridle wires (actually I am doing both just in case and too ensure same length). Any suggestions on how to get the bow tang off easily? I actually bent a flathead screwdriver trying to unscrew one of the screws. Can I get away with only removing one side of the tang and sliding it under? Any other suggestions are very welcome.
Eric
Atlanta, GA
edited by: Wolf_6, Jun 08, 2009 - 04:15 PM
The anchor bar for the bridal wires are aluminum and the bolt is stainless steel, this is the main problem they are hard to remove. I cut the head of the bolt off to be able to remove. When I replace the bridal wire I also replace the anchor bar with a stainless steel one, put in a new bolt and I add a nylon locking nut as well.
Hullflyer,
I knew I would have to cut off the bolt (already ordered new parts) but were you able to slip the wire in or did you have to loosen the top bolt? I am not sure what the top bolt has underneath and am afrtaid that once I loosen it I can never tighten it back.
