Painting a galvanized trailer
The bolts that are all connected to the trailer for the uprights, fenders,and mast holder have rusted and stained the galvanized rails.
This has also happened where the running lights connect to the trailer. Is there any way to clean the galvanizing to make it look newer.
dmcat1
Newcatowner
Check this out....fellow used CLR with scrubbing pad on his galvanized Whaler trialer.
http://www.continuouswave.com/ubb/Forum3/HTML/008293.html
edited by: sailinagin, Sep 26, 2010 - 10:25 PM
David
'84 Hobie 18 SE
Whatever you do, don't go at the rust stains with a wire brush, steel wool or similar aggressive tool. It will take off the galvanized coating pretty easy, then the entire "cleaned" are will rust, & look like POS.
Change those rusted bolts out & replace with SS bolts. If the bigger bolts are too $$ use galvanized bolts, they hold up pretty good, much better than zinc plated, way cheaper then SS
