P19 Barberhauler ni...
P19 Barberhauler nightmare
Rodrigo Fuenzalida
(@Pintue)
Hello everyone
At last I bought a wonderful P19. I have many questions about tuning up the boat. The main one is which could be the proper way to assemble the barberhauler. I had been looking for some scheme, photo or draw in the web, but I could not find anything. Please if someone have an idea, I appreciate your help.
Greetings from Chile
Rodrigo,
Pintue 🙂
Pintue
Posted : September 23, 2010 4:44 pm
Andre
(@ADixon)
Rodrigo,
Take a look at my Nacra 5.5SL barber hauler rigging. It may help you (or may not). The red line is a barber hauler line. The yellow line is a jib sheet. The blue line has nothing to do with them, it is mast overrotating line, which just happens to be there. The block, the jib sheet goes through twice, hangs on the end of barber hauler line and not attached to the front beam. As you pull on barber hauler line, it moves jib sheet and the point of pulling of jib clew down and aside. Also the barber hauler line goes through a cleat to hold it in desired position.
Andre
Colorado
Nacra 5.5SL
Posted : September 23, 2010 8:36 pm
Hi Pintue, congrats on the new boat!
incase you didnt know, (and you very well may) the barberhauler has a very limited range when it can be used. it is really helpful on a reach, but thats about it.
it is so limited i remove the line from my boat when i have crew just to reduce clutter on my deck. It would be the last adjustment i would worry about when getting used to a new boat.
enjoy and lets see some pics of where you sail!
Posted : September 24, 2010 4:38 am
Dustin Finlinson
(@Quarath)
Master Chief
Agreed. If I was you I would maybe even leave it off all together for the first season or so, or else set it and forget it and make sure the line is tucked out of your way.
Dustin
Magna, UT
Prindle 18
Posted : September 24, 2010 9:14 am
André
(@catmodding)
Agreed, keep it simple the first season.
Happy Sailing
André
P 18-2
Posted : September 26, 2010 2:53 pm
Rodrigo Fuenzalida
(@Pintue)
ADixon wrote: Rodrigo,
Thank you very much Andre Dixon for the clear photo and tips. It is exactly the same way I used it in my previous P18. MN3, Dustin and André de Bruin thanks for your advice. I will try to use it anyway. It used to be helpful in the P18 for downwind sailing, the jib showed a better performance.
I will upload pictures to share with you.
Greetings,
Rodrigo
Pintue
Posted : September 27, 2010 7:30 am
