P18 Split Jib Halyard Question?
You want to use the hog rings on this and not a knot, b/c the whole mess has to slide inside the luff zipper of the jib, and a knot doesn't go through there very well due to its size. Hog rings and hog ring pliers/crimpers are available lots of places. If you have a local Fastenal they might help.
Rob
Nacra 5.2
OKC, OK
Dustin, as you now know, you are looking for hog ring pliers. You buy the actual hog rings in different sizes, 1/4",5/16" etc, depending on the line thickness you are using. The rings are cheap, appx 15 cents each. If you are going to buy pliers ONLY for your jib, I would save the money & use a thin high tech line, & tie a reef knot. If you also need to replace shock cord on rudder up lines, buy a pair of pliers. You can make do with regular pliers, but they don't do as neat a job, & it is a real pain to bend the rings properly. If you are bending more than 2 rings it gets old, fast.
I bought some rings and experimented with regular channel lock type pliers. I bit of a pain but worked all right.
I'm not too worried about using clips for this. The picture was from either the old halyard that came with the boat or from a P16 I scavenged some stuff off of. I had my jib jury rigged a different way before I understood how the halyard was suppose to work so I was trying to remedy that this year. Anyhow very little strain involved for raising the jib and the halyard is not in any way used for keeping the jib up once it's locked in it's ring and the downhaul set, so I think the Rings will work good. If I had any experience with splicing and a kit for 3/16 line I'd just splice in a becket on each side.
They funny thing is. For my trap shock cord I like to be able to remove the cord easily at the end of the year and since on the Prindle the cord goes through some holes in the Tramp I did not want to make them permanent. So I just tie a figure 8 in the end push the knot back in the hole on the clip like it's made to do. No Hog Rings there.
edited by: Quarath, Jun 07, 2010 - 09:58 AM
Dustin
Magna, UT
Prindle 18
I use these:
http://www.apsltd.com/p-8040-hook-for-516-shock-cord.aspx
with 5/16" shock cord. They're huge hooks but do a great job and you can fairly easily undo them when you need to.
Rob
Nacra 5.2
OKC, OK
