p16 line question
I'm trying to rig up my p16 that I just purchased and have it down with a couple of exceptions.... one of which is the line/rope for both the mail and jib sails are needing replaced. The wire portion for the main is fine, but the rope part for both is shot.
I don't want to buy a full kit since most of it would be a waste, or at least not needed right now. Does anyone know the size of those two ropes? Looks like maybe 1/4 by I'm not sure?
What's confusing me is that on salty dog their line package shows:
Main Halyard - 3/16” (5mm) x 52' (1585cm) - White
Jib Halyard - 5/32” (4mm) x 22' (670.6cm) - Black (2)
But no way is it 52'... I guess if I replaced the wire portion with all line, then it would be 52', but as it is right now it's only the length of the mast so 26'. Is it supposed to be all rope and no wire???
Oh, and when pulling up the main sail I get about 2 - 3 feet from the top and it's almost impossible to keep pulling on it? I didn't put parafin wax on the sail, would that be it? Does that make a huge difference?
Thanks!
Ben
Chandler, AZ
Edited by bmerkley on Jul 16, 2011 - 03:00 PM.
It helps to use more technical terms if you can; halyards, sheets. There are no ropes on a sailboat. As for the halyard, it needs to be longer than the mast by at least a couple feet, 52 feet sounds long, 35 sounds better. Most Prindles are rigged half wire, half line. I will try to measure my line portion today on my P16.
As for the jib, do you have a zipper jib or wire luff?
When raising the main sometimes the luff can get caught so make sure that is smooth, also release the main sheet so there is no tension. If the main is getting caught in the exact same spot every time check the mast and make sure there is no debris or kink in the mast.
Edited by al.reed on Jul 16, 2011 - 01:25 PM.
They are the halyard lines, both the main and jib. The jib is a zipper. On the main line, it's half wire, half line so the mast is 26 feet and figured the replacement then would be the same but the 52' offered in the package at salty dog threw me off. And then the line for the jib goes up to the ring that is probably 20' up the mast so that 22' they show would be right, but then they show there is 2 of them. I only have one line for the jib.
I stand corrected on the jib, there are two lines for the jib basically... one going up, one going down so that's why they show 2.
But the 52' for the main halyard still throws me off. I'm going to assume it's a typo or something, I only need about 30 feet at most it seems.
And the jib line seems thicker than the main line, but according to that line package at salty dog it's the opposite. The main line is thicker (which makes sense since it would be carrying more weight I would imagine).
This is my first time rigging it up and just getting into sailing so thanks for any help you can give!
3/16" line for the main halyard is what it calls for but i installed 1/4" cause it's more comfortable on my hands...also the main only needs enough length to get the job done(~26' or so), just long enough to run through the center of the cleat and to attach to the shackle for trailoring/storage. the jib is in 2 pieces so when you have it raised, you unclip the extra and store it on the boat in the tramp pocket with the extra main halyard.
coastrat
Read post, then go read Prindle manual
http://www.thebeachcats.com/forums/viewtopic/topic/12634
http://www.thebeachcats.com/pictures/?g2_itemId=75669&g2_GALLERYSID=3602c3e2ec1ec0c51ab5b5646d860920
Turbo
On-The-Edge-Of-No-Control
As for trouble raising your sail that last bit the best thing is clean the track really well with soapy water. (I do this at the beginning of every season.) I use a sponge with a scrubber side that I fold and slide into the track where the sail goes in and run it up and down the track. You can use a washcloth or whatever works for you. While doing this watch and make sure your sail track is not pinched somewhere for the mast being dropped. That can make it difficult to raise.
After it dries I spray sailkoat into the track. Try to do this on an angle so the spray hits the inside front edge of the track as it doesn't help much to just coat the back of the track. I use the red straw and run a finger along the edge of the track to help guide the spray. Do both sides of the inside track.
Then liberally coat the entire bolt rope with sailkoat. Ti should go up a lot easier next time.
Dustin
Magna, UT
Prindle 18
sure there are.. i use ropes to tie down my cooler, radio, throwable pfd, and my anchor. I also use them on my trailer and occasionally on crew (kidding about that one).
Lines are used to control sails, spars, etc... ropes are for everything else (as i understand it)
Will also get some sailkoat, hadn't heard of that before. Thanks!
at about $20 a can (that may or maynot actually land on the right part of your mast track), i perfer to use $8 sillicone. I take a piece of soft white cloth and I wrap it around a pencil (actually broken part of a pen) and manually run it up and down my mast track (and liberaly spray the silicone on it). I lift the mast so i can get over the mast yoke (on the trailer). I do this a few times so that i clean and lube the track well all the way up. i do this a few times a season (but i also sail a lot)
I can see all the dirt and grime i am removing on the cloth and i know i am lubing the track, cause the cloth will run much easier when clean and lubed.
Fair enough. But what I meant was there are no ropes that come with a sailboat. Everything is a line. All those ropes you use are aftermarket, they are only 'on your sailboat' because you put them there.
Edited by al.reed on Jul 19, 2011 - 09:17 PM.
Thanks! I have another question, got all my new line but on the wire portion of the main haylard, there are these two pieces attached to the wire. They kinda look like they should be inside the main sail track in the mast, but mine are on the outside and that wire kind of just dangles around. Should these run along the inside of the track?
Hopefully you can see the below pic:
This might help
http://www.thebeachcats.com/pictures/?g2_itemId=75722&g2_imageViewsIndex=1
The only negative about the manual is the way is hops back and forth between the different models. Makes it hard to sort out what applies to a particular model. I wish I had a copy of the Acrobat editor software. It would be nice to be able to break out the different information into model specific documents. At least it does not have several different languages on each page.
I'm not seeing where in that page in the manual it addresses my question. Am I missing something? I have the manual and have read it, but I can't seem to find where it talks about if those pieces go inside the track on the mast.
I see where it says to hook those stops onto the haylard lock, but not anywhere that says if those slide inside the track on the mast or not.
Edited by bmerkley on Jul 22, 2011 - 12:53 PM.
The piece you are talking about is for raising the main. There should be a small fork-like metal piece riveted near the top of the mast on the opposite side of the track. When you raise the main that piece on the wire that you showed hooks under the piece on the mast so you know when you are fully hoisted. Does that make sense?
Yeah, that does and I get that part... I guess I still didn't know if that was supposed to go inside that track to sort of keep the sail in the middle as you're raising it. Sounds like it doesn't though, sounds like the way I have it is fine. Just looks weird sort of flopping around when I don't have the sail up.
Thanks guys, taking her on her maiden voyage this weekend.
bmerkley, your main halyard consists of 2 pieces, 1 part is wire and the 2nd part is non-stretch line, the line is fed through the mast head sheave from the aft side and 2 nico-press sleeves are swaged onto the wire approx 4 feet apart on the front side. The halyard does not run inside the track on the mast although at times one of the nicopress slug can/would work it's way into the sail track, don't worry about it, it will come out sometime. When raising the sail, pull main halyard at an angle away from the mast untill the sail hits top, then bring halyard perpendicular (parallel) to mast keeping the tension, you want that slug to hook into the halyard hook, it prevents the sail from dropping back down
There is a really good pic that Damon posted for you above, look at the bottom left pic, you can enlarge the pic, see how the main halyard runs between the prongs on the halyard hook? the slug gets trapped between those 2 prongs securing the halyard. Once secure, coil rest of halyard and tuck away.
Turbo
Usually when that happens to me, I release the outhaul that I forgot to uncleat.
---mike...
p16
