P16 jib halyard
I am going to a zipper luff jib and need to know the size and length of the jib halyard. It is not listed in the
manual. If anyone has a used one along with the s hook,
I would be interested in it.
Pete
edited by: pknapp66, Jun 24, 2010 - 04:49 PM
H18m
p16
Venture15
Barberhauler - 1/4? (6.4mm) x 16? (487.7cm)
Batten Ties - 3/32? (2mm) x 22? (55.9cm) (8)
Downhaul - 1/4? (6.4mm) x 15? (457.2cm)
Jib Clew Bridle - 3/16? (5mm) x 6? (182.9cm)
Jib Halyard - 5/32? (4mm) x 22' (670.6cm) (2)
Jib Sheet - 5/16? (8mm) x 33? (1005.8cm)
Main Halyard - 3/16? (5mm) x 52' (1585cm)
Main Sheet - 3/8? (9mm) x 40' (1219.2cm)
Rudder Pull Down - 1/4? (6.4mm) x 4? (121.9cm) (2)
Rudder Pull Up - 1/4? (6.4mm) x 5? (152.4cm) (2)
Tramp Lace Rear - 3/16? (5mm) x 10' 6" (320.0cm) (2)
Tramp Lace Side - 5/32" (4mm) x 11' (335.3cm) (2)
Trapeze Adjustment - 1/4? (6.4mm) x 3' 6" (106.7cm) (4)
Traveler - 5/16? (8mm) x 10? (304.8cm)
Dustin
Magna, UT
Prindle 18
From Salty Dog's catalog:
PRINDLE JIB HALYARD LINE WITH SISTER CLIPS $20.00
PRINDLE 16 MAIN HALYARD 3/32" (2.4mm) $46.00
PRINDLE 16 JIB HALYARD 1/8" (3.2mm) $41.40
My manual shows the halyard with sister clips. More confused than before.
H18m
p16
Venture15
If you had the old wire luff jib before, you will have to order a new upper forestay with ring and either cut down current forestay or order new forestay. Then you will need about 34' of 1/8 or 3/16 line with sister clips, S hook and halyard shackle. Pete
prindle pete
