p16 delaminating.
First, welcome to TheBeachcats.com!
Is this your first beachcat? Please introduce yourself a little more. You can set your signature for forum posts by going to
Personal Settings >> Manage your signature
I reccomend using
Your Name
Boat type
Location
in your signature to help other members help and get to know you.
On to your question. 😀
Yes, the rest of the foam sandwich could delaminate, but if you understand what causes it you can do prevention. Delam is caused by either/both moisture intrusion into the sandwich, or impact/flex usually from walking on the decks over time.
Does your boat have hull ports? I can't remember when the P16 switched production to include them. If not you should install some and leave them open whenever you can to keep the interior of the hulls dry.
And don't let people walk or jump on the decks, and don't run into things or let others run into you. That's about all the prevention you can do. Delam is NOT a normal process of aging, it's only common because the things that cause it are common.
what's happening geep?...besides your new old boat. i would recommend not doing the gel coat work until after the season winds down. get her out as much this summer as you can, you might find more spots as you go. also look at your keels, they tend to wear through and get thin. you can build up a couple of layers of glass to strenghten if needed. my friends old boss at the marina he worked at had a strategy for old boats..."pud" 'em up and use it this year and fix what you have to(needs)...then address the cosmetic stuff in the offseason(wants). the boat will tell you what it needs now and for the p-16 it useually is soft spots, new standing rigging, rudder tuneing, some sail repairs, stuck dolphin striker rod, mast rake questions, etc.. look at the home page here, it's full of p-16's coming back into service, hell, it might be the worlds largest collection of prindle sailors...and of course, pbeagle(prindle pete) is the man. good luck!
coastrat
Sry for the delay guys-OK Thanx Damon and coastrat. The boat does have hull ports-they are aft and port side under tramp- Not great but........ Can I add some as the later years had them (I cant find a trampoline without the cutouts) This is my first owned cat- I have sailed a few back-oh lets say way back. It was funny- I got her home and it never dawned on me that I had to stare at her for 3 days to remember how to rig. Lol-You guys should have seen my wife and the look on her face! She is English so imagine her saying "What have you gotten yourself into now?" I have several types of boats but the cats are a diff. animal for sure.
So the plan (long term) is to completely go through her and make her Excellent. Perfect, I have found with anything is a fools errand.. The port/bow deck is soft, nearly from crossbeam to bow-So I am doing the epoxy injection there before I put her in the water. Everything else is OK-mast is straight, all the rigging is there. But I got lots of questions..................The one thing I would like to know now is my boat did not come with a mast hinge-can I add one in any way ?
Your mast base casting on the beam should have area on the back side of the beam where some pins with ring dings on the end can connect the hinge piece.
Mast Base
Hinge
Pin
2 pins connect the hinge one side to your mast one side to the beam. On the bottom of your mast you should have another piece that you connect the hinge to.
I could not find a picture for it.
Dustin
Magna, UT
Prindle 18
Quarath wrote: Your mast base casting on the beam should have area on the back side of the beam where some pins with ring dings on the end can connect the hinge piece.
Mast Base
Just so there is no confusion, shouldn't that be called the "mast step"casting while the "mast base" is the casting attached to the bottom of the mast extrusion? Might make a difference when looking for parts.
i just replaced both castings(step and base) on my boat last month, bought them from murrays. the old ones wore so bad that the rotation had increased 1/2" and looked like it wanted to jump off when the mast came around hard. also installed new dolphin striker rod and ball. seems like most old ones(ds rods) seize up. matt said prices just spiked lately, have to check that out. i wasn't impressed with the new step base threads though, slightly crappy machineing but works fine.
coastrat
the mast base is stuck in the bottom of the mast(riveted) and the step base is mounted(riveted) on the crossbar with the dolphin striker threaded through it with the 1/2 round ball screwed onto the dolphin striker rod. i'd go fresh on all of these parts. the picture above is actually the step base that mounts to the crossbar, the mast base slides inside the mast itself. check out murrays under prindle factory parts, there is photos of all these parts there. if you really want to be as safe as can be then replace your standing rigging too...salty dog has the lowest price on sets.
coastrat
