Need new spreader tube for Nacra 5.0
Sorry for the delay, I forgot about it, then was out of country a few days working. I dug it up, bad news, I cut a piece off as it was the perfect size/strength to use as an insert in the thin tube of the H18 Magnum wings, although where it passes through the mast is in near perfect condition!
It is 3/4" OD, & 1/8" wall thickness.
A place like Metal Supermarkets or McMaster Carr has it. You want the 6061 round tubing.
https://www.mcmaster.com/#standard-aluminum-hollow-tubing/=17wsm9r
You would need to cut the end groves & drill the two cotter pin holes.
Have you tried giving Dan Berger, or Pete Begle, (they have ads here) a call?
They may well have a bent mast & could pull a decent one for you.
Edited by Edchris177 on Jun 03, 2017 - 01:54 PM.
