Need help with Nacra 5.2 Jib wire crap
Believe it or not, I'm actually putting a boat together!! I have been trying to get a 5.2 togerther for a friend for over a year, but finally gave up on it--hence, the ad in the classifieds. However, out of the blue, someone just contacted me because he wanted to sell his 5.2. Weird timing.
The boat is probably the nicest 5.2 I have ever seen except for the tramp. I had a spare one, but it didn't fit. Apparently, this is the wider tramp. figures. So, I bought a new one from SloSails. I ordered the slits for the jib wires, but for the life of me, I can't remember how to set up the boat so you can adjust the position of the jib block from the other side.
I remember there was a bungee that pulled it forward, then a line that went through the eyelet on the rear beam to a jam cleat or something on the end of the beam. This boat has nothing on the rear beam except the eyelets to attach the wire. I can figure something out, but does anyone have pictures of a smart way to set it up??
Thanks in advance..
Dan Berger
Nofolk, VA - Hobie Fleet 32
Supercat 15
A Cat USA139
yurdle wrote: I'll email you some pics -- I've got one set up in my driveway atm.
Rob,
If you can photo-document the rigging setup it would be great if you would create an album in the Technical section "Nacra 5.2 Jib Rigging" or something so future 5.2 owners could benefit.
I do get out to California, careful what you offer. =)
I made an album. It's not super thorough, but hopefully gets the point across.
The slot on a 5.2 is very tight -- too tight if you use the default jib wire locations and don't use a barberhauler. So, either use a barberhauler, or move the front eyelets (just add new ones) outward on the main beam. I put mine underneath as I run the front of the line/wire under the tramp -- the slots on the tramps are in all different locations so this is skipper's choice.
Like I've said before, I actually use a couple inches of barberhauler going upwind on the 5.2 to open the slot a bit. Otherwise they feel all powered up and go nowhere.
Rob
Nacra 5.2
OKC, OK
I am having the same problem with figuring out how to rig the jib. I am a recent owner of a 82 5.2 and it looks like I have the "deluxe" 4-way jib system. I have an unmodified tramp with the standard cables running fore and aft. What controls the jib trim, for and aft? I looked at the pictures posted by Yurdle but they don't relate to my boat. Help!
on a 1982 5.2 put the jib blocks on the jib wire so they can freely run up and down the wire
then run a line from the jib block back along the jib wire to the rear beam saddle, run the line through the saddle and tie a large stopper knot so it can't pull through
http://www.thebeachcats.com/pictures/?g2_itemId=79236
Edited by erice on Jul 02, 2012 - 12:58 AM.
1982 nacra 5.2
2009 weta
diamondlakesailor wrote: I am having the same problem with figuring out how to rig the jib. I am a recent owner of a 82 5.2 and it looks like I have the "deluxe" 4-way jib system. I have an unmodified tramp with the standard cables running fore and aft. What controls the jib trim, for and aft? I looked at the pictures posted by Yurdle but they don't relate to my boat. Help!
Can you post pics of yours then?
Rob
Nacra 5.2
OKC, OK
