Need Help Reeving
(@drmanhattan)
Hi all,
Just bought a pair of blocks for the downhaul.
I cant quite figure out how to reeve these with the becket located where it is.
Thanks in advance.
Posted : May 29, 2013 7:16 am
I would try this pattern but start on top at the becket
Edited by MN3 on May 29, 2013 - 01:24 PM.
Posted : May 29, 2013 7:22 am
(@drmanhattan)
I gave those a try with no luck. Im thinking I may have to add an eyelet on top of the cam cleat and using that as a becket. not sure though...
Posted : May 29, 2013 7:30 am
(@nacra55)
Becket needs to be on the bottom. What boat are you putting it on?
Ron Beliech
Nacra F-18
Brandon, MS
Posted : May 29, 2013 7:42 am
(@drmanhattan)
ya. after more experimenting I realized I need the becket on the bottom... do you think an added eyelet will suffice as a becket? Its for an H16 downhaul
Posted : May 29, 2013 7:46 am
(@nacra55)
If you mean putting an eyestrap above the camcleat, you may not have room for the tie off and the uncleated line in the space of the eyestrap but it's worth a try.
Ron Beliech
Nacra F-18
Brandon, MS
Posted : May 29, 2013 7:56 am
pete begle
(@pbegle)
I don't see how you need either becket. Start at cam cleat, go up to triple (to the side), down to cam cleat triple, then up & down twice and DEADEND on last sheave of cam cleat triple (with simple knot not allowing go thru sheave.). Pete
prindle pete
Posted : May 29, 2013 8:19 am
(@drmanhattan)
Ended up using the eyestrap as the becket. works perfectly. $60 for all parts. not too bad for a H16 downhaul.
Thanks all.
Posted : May 31, 2013 12:03 pm
(@fairyanna)
Newby
Ok... the boat unassembled. It took ages and about ten million knocks and hits with a mallet to remove a tramp. No other problems. Shall the next summer be here soon
Posted : December 16, 2014 6:11 pm
