Need help identifying material
There's an area about 3" by 5" under one hull where the paint or gelcoat is chipping. The layer under is still glossy like there was a lack of sanding in that area. The picture is not great but may be of some help.
I measured one chip with a micrometer and the thickness is 0.014". It is also very flexible. Also the underside of the chip is more brownish than white. It looks like paint but could it be a coat of gelcoat?
I want to be sure before attempting a repair.
I know it's not much information.
Thanks for your help.
looks and sounds like paint, I think that its safe to say 90% of the people that own our type of boats are going to freshen up hulls with a coat of paint over gel coat, one part vs two part, cheaper, more of a beginner to intermediate job, etc.
I would take the time to sand it and make the transition from the old stuff to the new stuff very smooth before painting. The 3x5 area will grow but it will be worth it in the end. Also sounds cosmetic and if you have a issue that big there because of bad prep you'll probably run into it somewhere else.
My 2 cents, since the season is fast approaching or maybe started where you live, I would sand a nice smooth transition that you can't feel, sail that this summer and do a proper restore in the off season. Since what you have there is almost certainly purely cosmetic.
No prob,
I didn't mean to talk down paint over gelcoat, Nothing wrong with a GOOD prep and paint job. But I definitely wouldn't want to miss sailing time over it! Especially on a I18!
You guys probably still have ice in Canada, eh?
Saw some floating by on lake Michigan last weekend.
If it is gel coat and rubbery I would think that maybe they didn't add the wax in the final coat. Gel coat will not cure when exposed to air. You need to over spray with PVA, or add the wax, or one of the available additives on the final coat to get things to cure hard.
