Nacra playcat aka E...
Nacra playcat aka Escape 2008 yellow loosey goosey mast
2 Users
(@goran519)
Newby
Hi
First post here, kinda know what I'm doing. I wanted to check with some of you how you woul connect shroud line without adjuster? Would you use just a small shackles?
Reason I'm asking is I currently have adjusters on both sides and lines are hooked up to the lowest hole...
I'm thinking just to hook up directly. Mast play in waves is scary, and i just want it tighter
Let me know what your thoughts are...thanks
Posted : September 19, 2016 4:51 pm
tim nell
(@tnell)
Does the for stay have an adjuster? Is it all the way down too?
Posted : September 19, 2016 5:10 pm
(@goran519)
Newby
HI, yes it does, it's in the middle hole on the adjuster.
If I put any more tension (to make it tighter that way) on it I will make mast come more forward. I really do t want mast any more forward
Posted : September 19, 2016 5:31 pm
