Nacra Infusion Crane Launching
Saw it every Wednesday last year, but with a Hobie Wave. The guy used 4 lift points - two lines, secured to cross bars. I can't recall if they were in an X-fashion or like a sling in the front and one in the back, secured next to the hulls. Worked really, really well. He was using the same davit crane used to launch the keel boats. You'll just need to have plenty of time to adjust the rigging so you get a good balance at the crane. I think the guy might have even left the lines attached, though that wouldn't be my first inclination with more lines on the boat while sailing...
I used to live on a canal and launched my 18 ft cat with a davit. The "sling" I made was four pieces of 3/8ths line that were connected to the cross tubes and terminated at the top to a steel ring. Where each of the four lines connected to the cross tubes, I used a hook and just wrapped the line one turn around the cross tube and hooked the line to itself. A knot in the line kept the hook from sliding down and coming in contact with the cross tube. You want to have the lengths of the line adjusted so when the boat is lifted it leans forward enough to keep the shrouds from coming into contact with anything.
I used to launch my N5.0 from a power travel lift. I made 4 loops of 1/4" that protruded from the beams. (knot within the beam) and used 4 adjustable straps (non-ratchet) to set the pitch of the boat off the hook. You can mark the straps with a sharpie or use the final adjusted length to make a harness from there.
However, when lowering one must be certain that the motor for the lift does not end up in the stays or diamond wires and dismast the boat. With the mast raked back and the bows down it is difficult to pull the boat away from the crane to avoid collision as the bows land in the water forcing the boat level again.
It is definitely worth a shot, just don't commit to lowering once you have started because it may just not work out on a high dollar boat. YMMV
Rob
I might up end up using 4 loops of 2inch webbing, looped behind the rear crossbeam and in front of the front beam. Ending up anchored to the beam to stop them from slipping forward or aft.
Think there needs to be more straps in the middle to help relieve the middle of the hulls?
I've ONLY seen them picked up by the crossbars, never supported by the hulls. That is, I think wrapping straps around the hulls MIGHT be a bad idea. On the flip side, picking up by the crossbars seemed to work remarkably well. I can't recall how the guys made sure the straps wouldn't slide in on the crossbars towards the center as he lifted, but it seemed very, very stable. I think he may have just wrapped the lifting straps around the crossbars in between the trampoline lacing and the lacing kept the straps from sliding. Not like there's a HUGE ton of force trying to make the straps slide....
