Nacra I-18 tramp pulling out of rail.
Is it the I-18 where the track is fiberglass and made into the hull?
See this tread on Catsailor.com There are some others but it is the newest.
http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=246739#Post246739
Ron Beliech
Nacra F-18
Brandon, MS
The quick fix is pull the tramp off and add 2 layers of black duct tape to the bolt rope. Silicon up the slot/tramp as you re-install. A longer term fix is I had my local sail/patch/tramp guy add a layer of 3 inch wide black strapping (webbing) over the bolt rope. Mine still pulled out a touch by the end of last season. A friend gave me some shims that H16 guys use, I have not tried them yet.
The end solution is when I need a new tramp (1 or 2 more years). I will use sail/mast slugs and make the tramp slightly narrower and with grommets/eyes rather than a bolt rope.
I will see if I can find the shims and take a pic of the packet. A fellow sailor on the beach literally just handed them to me, I don't know where you get them or anything, but the duct tape WILL HELP!
--Norm
Edited by nhanson on Apr 23, 2012 - 10:26 AM.
I used high quality black duct tape. the glue/tape will last almost all summer. the $5 a roll stuff not the $0.99 a roll stuff. you run the tape length wise along the bolt rope in a single piece. Then go right over that again to thicken up the bolt rope. Obviously start with everything nice and dry/clean/free of sand.
