Nacra 6.0NA Mast Tang - Repair vs. Replace
I recently purchased a Nacra 6.0NA and noticed that the mast tang for connecting the forestay is slightly deformed and a crack has started appears where the forestay shackle goes. Murrays indicates that the old tang is not longer available and you need to purchase a new tang and re-drill some holes in the mast. The tang looks very similar to the one on a Hobie Tiger. I would rather not remove existing and re-drill into the mast. Two questions:
1. Does anyone know if the Hobie Tiger/F18 mast tang is the same as a Nacra 6.0NA?
2. Is it possible to repair the existing tang by welding the hole?
3. Has anyone replaced a mast tang for a Nacra 6.0NA?
I have a photo, but cannot seem to figure out how to upload the photo.
Devin
I think I have a spare, but the cheap and easy fix is to weld it and redrill the hole.
I have welded them in the past when the hole gets elongated to a point of failure. Make sure you get a guy welding who has some experience with stainless and make sure to use heat sinks.
