Nacra 5.8 main sheet 7:1 diagram, anyone….? Or picture..?
This is a picture of a low profile 7:1. Click on the pic to enlarge.
https://www.thebeachcats.com/pictures?g2_itemId=130420
Edited by pknapp66 on Jul 20, 2021 - 07:04 AM.
H18m
p16
Venture15
pknapp66 wrote: This is a picture of a low profile 7:1. Click on the pic to enlarge.
https://www.thebeachcats.com/pictures?g2_itemId=130420 Edited by pknapp66 on Jul 20, 2021 - 07:04 AM.
The irony is that mine does not have the anchor loop below the top block. It only has it on the bottom.
You need to be able to tie off at the top block to go 7:1. If you have Harken Carbo blocks (like shown in the 3rd post of this thread), you can pass the end of the sheet through the center of the upper block and tie off with an 8 knot. Or if your boat has a boom, you can add another boom bale and tie off to that (but I believe the 5.8 is boomless). Otherwise you’re going to have to get creative because if you can only tie off to the lower block, the most you can get is 6:1 purchase.
Steve M.
Just so you can call things by the correct names:
I have a new [del]rope[/del] to install in my block that came with the boat that was definitely [del]strung[/del] wrong.
if it controls a sail it is called a sheet
you don't string blocks, you reeve them
[del]anchor loop[/del] below the top block
you tie off to a becket (or a Strop if it is cloth)
Dogboy wrote: You need to be able to tie off at the top block to go 7:1. If you have Harken Carbo blocks (like shown in the 3rd post of this thread), you can pass the end of the sheet through the center of the upper block and tie off with an 8 knot. Or if your boat has a boom, you can add another boom bale and tie off to that (but I believe the 5.8 is boomless). Otherwise you’re going to have to get creative because if you can only tie off to the lower block, the most you can get is 6:1 purchase.
I wish I had the becket at the top...But it is on the bottom, and the reverse of all the modern blocks I am finding, that have the becket in the middle and the small block out front.
Mine is just slightly different...Cannot seem to find mine anywhere.
