Nacra 5.8 jib fit a Prindle 18-2?
Hi guys, purchased a Prindle 18-2 last year and ended up rebuilding the thing.
Looks good, but never had a Jib on it, so looking for one.
Came on one from a Nacra 5.8 and he gave me all the lengths on it, but can't find any references to the Prindle 18-2 to compare them to.
I know the mast on the 18-2 is the same as the Prindle 18, so do they also share the same Jib as well?
Thanks for any help!
It's 10% larger on the 18-2. Can't comment on the cut, but you can look that up at the sailmakers.
Not that big a difference, right? I sail both boats and I greatly prefer the 18-2 jib.
https://www.thebeachcats.com/pictures?g2_itemId=127183&g2_imageViewsIndex=1
Thanks! lot's of good information in that link.
So, a Prindle 18-2 is a different size jib than a Prindle 18, got it!
Now, is there any sail makers sites that I could look up the actual sizes of different sails for a particular cat?
Like which other cat's jib could be effectively used on the 18-2 if I can't locate a used one?
I've asked for quotes for one, but haven't received them yet.
Here's a quick look:
https://www.thebeachcats.com/pictures?g2_itemId=127183&g2_GALLERYSID=e566d3e539f8b65a284c57678254274c
There is lots of data in this album about the 18-2.
You shoulda talked me out of it... Wasn't that great.
The first tack felt good in moderate 12-15mph but it felt sluggish after that. On the 18-2 it is anything but.
Observations:
The square top was slightly shorter and about a foot and a half wider so I had to use the longer boom from the 18.2. It went up smoothly, but was harder to hook in with all that material at the top.
With the boom extending farther aft of the tiller, the net effect was more trouble sheeting hard with the traveler centered. When you traveled out, things lined up better and there seemed like the sail generated more power and you could pull the tack lower. It worked well with the smaller P18 jib. The boat seemed to point higher, but was not faster on a reach, as I expected.
Downwind, the square top was a much nicer profile and the battens performed better.
All, in all, it was very stable with the extra top area, on all tacks and wind speeds. Flying the hull was not any trickier but getting her up there was harder. Fun - but not the kick in the pants I had hoped for. π
