Nacra 5.7 rudder blade vendor
Hey folks,
I have found exactly one vendor having rudder blades for Nacra 5.0's/5.7's in stock:
https://bnrwatersport.com/parts-categorized/rudders-blades/nacra-5-0-5-7-rudder-blade-detail.html
Is there anything I am missing. Can you guys help me out?
I'd also be interested in used rudder blades that still do the job.
Br from Germany!
Hey Lars, thank you for your answer.
Maybe nothing's with it. I do not know. That is the problem. If there were multiple offers, potentially with different rudder blades for my 5.7, I could compare and tell.
So I'd have to trust this vendor.
By the way, do you know him personally as you're referring to his first name?
Br!
Hi,
Not personally, but I know him as a serious seller, as I have bought quite a lot from him through the years. It is a goldmine for me, as I, exactly as you, sail old Nacras(5.5 and 5.8) and other obsolete multihulls. Remember it is an over 20 years old boat and Nacra don´t produce spares. Have bought sails, 5.8 hulls, rudder blades and a lot of other items. It works for me 🙂 .
Br from Germany!
Do not buy used rudders from a 5.2, which are more readily available.
Rudders from a 5.0 will work, they’re the same as used in the 5.7.
Look at your hulls from a side view. Notice the skeg hull boats have a definite rise towards the rear, from where the skeg ends. The non-skeg boats do not have that rise, and use a shorter rudder. If you use one of the rudders from say a 5.2 it will be about 4 inches too short.
https://www.thebeachcats.com/pictures?g2_itemId=119559&g2_imageViewsIndex=1&g2_GALLERYSID=60b5ae97287e1cc670bb8c09def841ec
Off course one should use the correct rudder for the boat.
5.0, 5.7 are the same. 570 might also be the same but the holes for the rudder holder has then to be redrilled.
Max! I might have a 5.7 or 570 rudder in my workshop for you, must check next week.
To clarify these are the correct ones:
5.0/5.7
Might work, anyone who has checked? 570
The totally wrong one:
Edited by revintage on Apr 29, 2022 - 04:57 AM.
maxn5.7 wrote: Hey folks,
https://bnrwatersport.com/parts-categorized/rudders-blades/nacra-5-0-5-7-rudder-blade-detail.htmlIs there anything I am missing. Can you guys help me out?
I'd also be interested in used rudder blades that still do the job.Br from Germany!
You can purchase all the new Nacra 5.0/5.7 rudders (they use the same rudder) you want from the Nacra folks in Brisbane AU. They still make the 5.0 there and have all of the parts that will fit our legacy Nacras in the USA.
Or, get ambitious and hang a set of Hobie 14,16,+++ rudders on it, they're plenty long enough.
https://www.thebeachcats.com/index.php?module=forums&func=viewtopic&topic=17608
Edited by leeboweffect on May 30, 2022 - 10:37 PM.
